Possible to modify a magnet to be more beamlike
  • Thread starter Thread starter stalnakerz
    Magnet
Modifying a magnet to achieve more beam-like characteristics is challenging due to the nature of magnetic fields, which require a path from the south to the north pole. Encasing a magnet in ferromagnetic material, such as a preformed iron or steel box, may help focus the magnetic pull directly in front while minimizing it elsewhere. Using a rod magnet wrapped in ferromagnetic material with a mu-metal shield could further limit field spread. However, achieving efficient pull typically requires specific shapes, like pancake coils, which may not provide the desired range. Commercially available specially polarized magnets might offer a solution by attracting strongly when aligned and repelling when misaligned.
stalnakerz
Possible to modify a magnet to be more "beamlike"
I've been wondering if it is possible to encase a magnet in something readily available that would give it more beam-like characteristics vs. field. Basically, I want to have the magnet encased so that I would get full magnetic pull on an object directly in front of the magnet but little or none when the object is not directly in front of the magnet.
Not that I know of. Magnetic field loops need to have a path from the south to the north pole, although if the field loops were mind-numbingly huge it might seem to act like you want...
That's actually what' I'm looking for. The loop to be large on either pole but keep very close to the magnet itself on the sides.
Mu metal will help but there is no way to totally shield a magnetic field. Magnetics Inc. sells it but it it expensive. Try making a shield out of a ferromagnetic metal and it will likely work about as well. A preformed iron or steel box with open ends will work pretty good.
Actually, I've been looking around and I think that for my application I'll use a rod magnet wrapped in ferromagnetic material with a mu-metal shield around that. Hopefully that will allow the field loops to pass through the ferro material while limiting the spread of the field. As soon as I get the money up to buy all the materials I need, I'll reply to this thread and let everyone know how it's working.
Remember that the pull on an object (a magnetic dipole) by a magnetic field has nothing to do with the strength of the field as such, but with its gradient. Thus, a uniform field confined to a cylinder wouldn't actually pull anything.
Unfortunately, really efficient "pull" requires a pancake shape coil and that will have little throw.
http://www.correlatedmagnetics.com/
These people have specially polarized magnets that attract strongly when properly aligned but repel when slightly twisted or moved off-axis. Not sure if this is exactly what you're looking for in a magnet but it's the closest commercially available product I know of that seems to match your description. Cheers.
This thread is 4 years old.
