Understanding Potential Difference in Simple Circuits
  • Thread starter Thread starter xyx
The discussion revolves around understanding potential difference in simple circuits, specifically comparing the voltage drops across bulbs in different configurations. In the first example with one bulb, the full 12V drop occurs, while in the second example with two bulbs in series, the voltage drop across the first bulb is 8V. Participants clarify that the energy deposited per electron is less in the second example due to the reduced current, which affects how much energy each electron can transfer. The conversation emphasizes that voltage is defined as energy per charge, and the initial energy per electron remains constant regardless of the circuit configuration. Ultimately, the key takeaway is that in series circuits, the distribution of voltage depends on the current and resistance of each component.
xyx
Hi,
Sorry to bring this up again but I've been looking so long for an answer to a new question that arrised.
This is how I see it and tried to explain it, so please correct me if I'm wrong.
example 01: 1 bulb in a simple circuit : 12v ,
bulb 01 : 2ohm
expln: potential energy drops by 12 v over bulb; Ok np so far.
example 02: 2 bulbs in series: 12v ,
bulb 01 : 2 ohm , 8v
bulb 02 : 1 ohm , 4v
But here's my problem: THE DIFFERENCE IN V. (POTENTIAL DROP) OVER BULB 01 IN EXAMPLE 01(12v.) AND BULB 02 IN EXAMPLE 02(8V).
Which one is the right explanation?
EXPLAINATION 01:
The energy needed per electron to pass through bulb's 01 ions is still the same so each electron loses the same energy per coulomb but there are less passing so the drop in energy is less over bulb 01.
Since there are less q/s(I)(more energy to spend per electron) every electron starts with more energy (more then with just one light bulb)so it also can get past bulb 02.
But this is a bit in contradiction (to my textbook) with the fact that the potential drop is said to be 8v per coulomb on bulb 01, so the [del]E/q, the drop per electron(loss in energy to go through bulb 01), in bulb 01 is in my above explanation still 12v but since there are less electron the v-meter measures less namely 8v.
EXPLAINATION 02:
The energy needed to pass through light bulb 01 IS less then in example 01 because I is smaller and therefore there is less energy loss in the same bulb(bulb 01) for some sort of atomic reason I don't get(maybe because the electrons are moving less fast)?
correction on line 12: I meant "and bulb 01 in example 02(8v)".
EXPLAINATION 01:
I think there is no 'energy needed to pass through'.
Imagine you operate a bulb at very low voltage, so that it does not glow.
You will find that there is a current. In fact, the bulb is a good conductor when it's cold.
Yes, the current is small then. But not because electrons don't have the 'energy needed to pass thru'. The current is small because the electrons move very slowly. Remember, current=charge/time.
I think this is false. Voltage is energy/charge. So, in example 02 each electron does in fact deposit less energy in bulb 01, than it does in example 01. If you so will, it 'saves' some energy for bulb 02. Yes, there are less passing but this has nothing to do with how the 12V distribute over both bulbs.
No. In both examles, each electron starts with exactly the same energy.
The potential drop is just 8V = 8joule/coulomb. If your textbook uses the unit 'volt per coulomb', then it is wrong.
No. The voltmeter measures volts. Which is basically energy per electron. The initial energy per electron is a sole property of the source, no matter what circuitry you connect. (If it's an ideal source, which is the case here).
EXPLAINATION 02:
There is no 'energy needed'. There only is 'energy deposited' per electron. And that's in fact less in example 02 than in example 01.
You're getting closer. The electron deposits less energy in bulb 01 because it moves slower. (And I is smaller also because of this).
The 'atomic reason' is, if you so will, collisions between electrons and atoms. If the electron is slower, it loses less energy in a collision.
Yes.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
