Potential at Center of Insulating Spherical Shell
The discussion revolves around calculating the electric potential at the center of a spherical insulating shell with given inner and outer radii and a uniform charge distribution. To find the potential at the center, the electric field must be determined in three regions using Gauss' law: outside the shell, within the shell, and at the center. The potential at the center and at the inner radius is calculated to be 8.60 * 10^2 V, aligning with the potential at the inner radius. The key challenge lies in correctly applying Gauss' law to derive the electric field in the region between the inner and outer radii. Understanding the relationship between electric field and potential is crucial for solving the problem effectively.
waters
The inner radius of a spherical insulating shell is c=14.6 cm, and the outer radius is d=15.7 cm. The shell carries a charge of q=1451 E−8 C, distributed uniformly through its volume. The goal of this problem is to determine the potential at the center of the shell (r=0), assuming the potential is zero infinitely far from the sphere. In order to do this, we will first determine the electric field everywhere in space due to this charge distribution, and then use the relationship between the electric field and the change in potential to find the potential at the center.
Finally, apply the relationship between the change in electric potential and the electric field and the value of the electric potential at r=c, to find a numerical value for the electric potential at r=0.
dQ = ρdV
∫E●dA = q/ε
ε = 8.85 E-12 F/m
-∫E●dl = V
r(unit vector)●dl = dr
V = kq/r
The charge density, ρ
ρ = q/((4/3)pi(d^3-c^3)) = 3q/(4pi(d^3-c^3)
The charge differential, dq
dV = 4pi(r^2)dr
dq = ρ(dV) = (3q(r^2)dr)/(d^3 - c^3)
q = ∫dq
The electric field is either:
E = q/(εA)
or
E = kq/(r^2)
However, if I evaluate ∫E*dr for both equations, I get the wrong answer for the potential at c. I don't even know if I should use dq, or q. The potential at c is the same potential at c (I don't understand why or how). I just know that
-∫E●dl from infinity to c = (-∫E●dl from infinity to d) + (-∫E●dl from d to c)
should give me the potential at c (and the center), but it doesn't. The potential at d is (8.30*10^2 V), which I got right.
E = q/εA
-∫E●dl = V = ∫(qdr)/(4*pi*ε*(r^2)) from infinity to d
The answer to the potential at both the center and when r = c is 8.60 * 10^2 V.
Please help me out. I have a test on Monday, and I need to know how to do this problem.
You'll need to use Gauss' law to find the electric field in the three different regions:
(1) r>d (2) c<r<d (3) r<c
You should find that Gauss' law gives E = kq/r^2 for r>d, which is why you got the potential at r = d correct.
The toughest part of the problem is using Gauss' law to find E for c<r<d. But you already have the charge density for this region. That will be useful when using Gauss' law.
For r<c, Gauss' law will give you a simple result for E.
You have the right idea for finding V from E.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
