Potential difference 'inside' a capacitor
The discussion revolves around the potential difference (P.D.) measured inside a parallel plate air capacitor compared to the P.D. measured at the terminals. Participants explore the implications of measuring voltage across the plates, the behavior of electric fields within conductors, and the effects of charge accumulation on potential difference.
  • Some participants suggest that measuring the P.D. from the inside of the capacitor will yield a higher value than the terminal measurement, proposing a direct proportionality to the distance between the plates.
  • Others argue that the potential difference across the plates should be the same as that at the terminals, citing the absence of an electric field inside a conductor at steady state.
  • A participant mentions that if the capacitor is dismantled, the P.D. between the plates would be higher than that of the charge source, implying a change in capacitance and charge distribution.
  • There is a discussion about the nature of work done in a conductor, with some suggesting that work can occur due to collisions rather than solely in an electric field.
  • One participant introduces the concept of superconductors, proposing that in such cases, the current would be infinite, leading to questions about energy dissipation through resistance.
  • Another participant emphasizes that the potential difference calculated using the formula Q = CV may not reflect the actual potential difference when considering the charge distribution on the plates.
  • Concerns are raised about the assumptions made regarding the thickness of the plates and the implications for measuring potential difference.
Participants express differing views on whether the potential difference inside the capacitor differs from that at the terminals. There is no consensus on the implications of charge accumulation and the behavior of electric fields within the capacitor.
Participants note limitations regarding assumptions about the electric field in conductors, the effects of capacitance changes upon dismantling the capacitor, and the implications of using superconductors in the discussion.
dE_logics
Suppose we're measuring the P.D of a parallel plate air capacitor from the inside (i.e from the side the 2 plates face each other), will it be different to when we measure it the normal way (like when discharging it)?
I think it will be more when measuring it from the inside...many times more, and will be directly proportional to the distance between the plates.
Where are you talking about measuring the voltage? If it's across the inside of the plates then it would be the same as at the terminals.
Why?...the charge accumulation will be high inside the capacitor...this is a must, else the actual charge stored in the capacitor will be extremely less, the extra charge stored is by virtue of extra potential difference on the plates...else there's no way the plates (considering their size) will be able to hold that much amount of charge in the parallel plate air capacitor.
A manifestation of this fact is that, if the arrangement is dismantled, the P.D between the dismantled plates will be much higher than P.D of the charge source.
I'm not sure what you are trying to say. The potential difference is the energy it takes to move a charge between two points in an electric field. There is no electric fied inside of a conductor at steady-state. So there is no potential difference between the terminals and any point on the surface of the attached plate. The voltage between the terminals would be the same as the voltage between two points on opposite plates barring the various perturbations in the voltages due to the finite size of the plates.
I'm talking about a parallel plate capacitor and the P.D from its inside, i.e not the way we usually connect the capacitor to the external circuit but the path though which the dielectric leakage occurs.
You did not get the question, and I think no one did.
I think he's asking whether there would be a difference between the P.D. from the outer sides of the parallel plate capacitor and the inside sides (the distance between the "inside" sides of the capacitor differs from the "outer") Actually I don't really get it either, do we assume that the plates have negligible thickness for parallel plate capacitors?
Yes.
Ok, this might explain -
Yes, that is how I understood your question. Again, the answer is that the voltage is the same. The potential difference is the amount of work required to move a charge in an electric field. Inside a conductor, there is no electric field at steady state because the charges are free to rearrange themselves to cancel out any applied electric field. This means that no amount of work is expended to move a charge from the terminal to any point on attached plate. Thus, the potential difference between the terminals is the same as the potential difference between any two interior points across the plates barring the variations in the voltage due to the finite size of the parallel plates.
The work done in a conductor is by virtue of collision of collisions in on the kernels rather than the charges working against a field...so its not necessary that work by a charge is only done in a field.
Anyway since we're considering superconductors, there will actually be no work done inside the conductor...so if we're connecting the inner side of the plates with superconductor, the the current will be infinite, so to put things in terms of real life cases, let's add a resistance...to this...so I'm asking what will be the energy dissipated through that resistance in an infinitely small time interval.
I'm not getting you...I decoded what you said as work cannot be done by a capacitor.
This is why I think so -
"We can compute stuff using Q = CV, which's a general relation for capacitors.
The Q here will be the net charge accumulated and V will be the potential difference across the plates of the parallel plate air capacitor; note that while using this formula, the arrangement is taken as an 'object' rather than a 2-plate arrangement that is there will be a difference between “the potential difference in each plate by virtue of the charge stored on each of them” and the V that we assume here (that just appears on the back side of the plate).
So...how do we know that there's so much charge on the plates?...how do we measure it and how do we get the 'real' potential “by virtue of the charge stored on each of them”?
There are 2 ways...the simple one is to separate the 2 plate, that way the charge will get exposed throughout the plate, and we'll be able to see its actual potential. On doing so, the V assumed will be different from the potential difference between the plates (that appears on dismantling the arrangement), why...cause on dismantling the plates the capacitance will decrease; remember that the capacitance (or charge per unit volts) of the arrangement and the 2 plates as separates entities are different, the dismantled situation having a lower capacitance...so on dismantling, though the capacitance will decrease, the charge wont...so what will happen?...the P.D will increase to as to store that specific amount of charge on both the plates (a property of their individual capacitance).
The other way is to do so is to connect the plates form the inside, since almost all of the charge has been accumulated on the inner side of the plates, the density will be high, and so will the potential (that's why a dielectric leaks). Connecting the plates from the outer side won't give you that much a potential difference, it will be equal to that of the voltage source.
It cannot be stated that this V computed from between the plates of the capacitor will be equal to the V assumed in Q = CV, that's cause the charge stored on the plate is extremely high and as said before, by virtue of that charge stored the P.D should also be extremely high; the only way the P.D can be reduced is when there'll be a charge difference on both the plates so as to make a lower P.D (equal to V)...but apparently the charge stored on each of the plates is equal and opposite...so this can't be said. Measuring this potential difference (between the 2 plates from the inside) will be like directly measuring the P.D between the 2 plates infinite distance apart (as done before), and that will definitely be higher than the predefined V.
Since the potential difference towards the inner side will be high, the capacitance of the arrangement will be low if that P.D is measured."
I'm not assuming superconductivity of any sort here. When we talk about conductors in basic electrostatics we are talking about perfect electric conductors. But, if you want to consider a realistic conductor, the answer is the same within normal lab equipment precision. The conductivity of copper and any good conductor is on the order of 10 M Siemens, compare that to sea water which is on the order of 1 Siemen. The resistive lost between the terminal and plate of the conductor will be negligible. We often just replace metals with a perfect electrical conductor because the difference in the results are generally lower than the accuracy of our calculations. Either way, the answer is the same, because there is no electric field residing in a conductor, the voltage drop between the terminal and any point on the inside of the attached plate is zero. Thus, the voltage between the terminals is the same as the voltage between two points on the inside of the opposite plates.
This is not true, if that's the case then why is the calculation of the voltage between the plates wrong in the first place? I can't follow your logic here, but I can assure you that you are doing something wrong to come to your conclusion. You should note that when we calculate the voltage and charge distribution of an ideal 1D parallel plate capacitor that we do not bother with terminals or care about the thickness of the plates. The plates can be infinitesimally thin, in which case there isn't a difference between the inner or outer sides, they are the same.
I don't know but to me it seems like a mixup of electric field and conductors...anyway, it doesn't have to do with the topic at hand. :-p
Yeah...that's the problem, I don't know what's wrong, this is the conclusion that I came to using/following basic principles, but this is not seen in real life.
Can you pls quote the things that you're not getting?
Thickness doesn't matter anyway.
Most probably this is a misunderstanding, an infinitely thin plate has the ability to rupture or even terminate a field, it can cause major impact if earthed.
We can't ignore a standing thin, ideal and earthed conductor in a field, it ought to have an impact.
mr.survive said:
,V=Q/C..now charge accumulation may vary but have u noticed C ?
C acts as a constant of proportionality for the individual body/capacitor. I've attached a section of my notes to describe what it is...I've considered that too.
why don't u calculate it in simple way where dV=Edr
I'm doing analysis of what is happening, calculating is and figuring out the answer is not the reason, I need an explanation of the phenomenon.
Anyway, in https://www.physicsforums.com/showthread.php?p=2174515#post2174515" thread we discussed that and came to the conclusion that the expression in native form is useless for a capacitor.
n u already know E for II plate capacitor s E=sigma/?
No I don't.
Simply doing a mathematical analysis without having the slightest understanding of the theory is sheer stupidity...this is what is ruining the education system at least in this god damned place.
If only do mathematical analysis, you will most probably end up with a wrong conclusion/answer unless the same sort of question is asked thousand times like in this place; furthermore you will not be able to answer a question out of the usual 'numerical' question.
I'll try and make this clearer by adding 3 words -
It cannot be stated that this V computed from between the plates of the capacitor will be equal to the V assumed in Q = CV, that's cause the charge stored on the plate is extremely high and as said before, by virtue of that charge stored the P.D *on each plate* should also be extremely high.
So much rhetoric over a simple problem, I haven't the wherewithall to read.
1) Assume there is a potential difference from one side of a plate to the other.
2) Charge will flow until the diference in potential is zeo.
3) The potential across any plate under static conditions is zero.
4) Therefore the potential difference is the same, measured from the inside of the plates, or the outside of the plates.
Why do you think that the charge has to be high? Take a look at cabraham's derivation from the previous capacitor thread. You can solve for the voltage and charge distribution on the parallel plates. If you want to do it for a finite plate size, there are a myriad of ways to do it by using a method of moments technique, I think Harrington's book has an example of this in his electrostatics section. Either way, I'm not sure why the charge has to be "extremely" high and not be correlated to the potential difference that we solved.
As for the thickness of the plate. I did not say that an infinitesimally thin plate would not have an effect. The capacitor would have the same voltage regardless of the thickness, as you say, and that is my point. With an infinitesimally thin plate, there is no inner or outer side. So the paradox that the inner voltage would not be the same as the outer voltage will not work here because the inner and outer surfaces are the same. However, you will still get the same voltages and charges if you solved assuming an infinitesimally thin plate.
This point can be proved wrong if you place 2 equally but opposite charge plates in front of each other and Earth one...what will happen?...charge will double on the earthed plate, so the difference in potential has been doubled between the plates.
aaaaa...I sort of didn't get any relations between this and the previous points.
Ok...what I mean by 'high' is as compared to a single plate, the charge stored on it by virtue of the potential of the charging source will be very low as to when the same plate will be in a capacitor arrangement...so the charge stored on it will be very high, and this charge will get exposed on dismantling the capacitor arrangement.
I don't know anything about vector calculus :frown:
Anyway, mathematical analysis using this logic (that the P.D will be different for the inner and outer side) can also be done.
humm...but you still have some thickness...I mean taking it as 0 is not ok...the thickness is extremely less or negligible but not 0...so there will exist 2 faces "infinitely small distance apart".
No, you can assume that it's thickness is 0. We do this when we do electromagnetic simulations.
This is what I have been repeating through this whole thread. The is no voltage drop across any two points on a continuous conductor when we are at steady state in electrostatics. This is because there is no electric field inside a conductor. This is because charges will always arrange themselves such that they perfectly cancel out any applied electric field in a conductor. Thus, because there is no electric field inside a conductor, then no work against an electric field needs to be done to move a charge which means that the voltage drop is zero. This means that the voltage between the inner and outer edges on a the same plate is zero.
And again, I can see no logic as to your claims. You say previously:
But there is no explanation to support this. You want to know the charge on the plates? You solve the Laplacian like cabraham showed you. You want to know why the voltage between the inner and outer surfaces of a plate is zero? You solve for the voltage using your knowledge of conductors and electrostatics.
dE logics think of the capacitor plates as two resistors.Will there be any voltage across them when the current is zero?
Without any reason?
Oh...now I get it.
:smile: The whole thing is itself an explanation...how can you explain an explanation :smile:
Anyway, I think I first have to see to it why a P.D or even a field does not exist in a conductor.
No.
I think i get it. The plates are conductors so that means they are equipotential surfaces--every point on the surface of the plates are at the same potential.
No, no. This was in reference to a single plate. If there is a potential gradiant inside a conductor, there is an elecric field inside the conductor. Charge will flow under the influence of the electric field. Charge will flow such as to bring the electric field to zero throughout the conductor--the resultant steady-state condition.
the voltage will be almost the same, except for the small resistance of the plates, and any stray capacitance.
not so. not through these mechanisms.
  • · Replies 16 ·
  • · Replies 33 ·
  • · Replies 58 ·
