Potential energy algebra problem
To solve for height h in the potential energy equation PE = mgh, isolate h by dividing both sides by mg. If the object is moving, equate gravitational potential energy (GPE) to kinetic energy (KE) to find h. For a stationary object, the simplified approach directly leads to h = PE/(mg). The discussion emphasizes understanding the algebraic manipulation rather than just obtaining the answer. Mastery of these concepts is essential for learning physics effectively.
electr0n
The equation for potential energy, PE, of a mass m and at height h, where the acceleration due to gravity is g, is PE =m*g*h. Solve for h.
* = multiply
If someone could please tell me how to work it out and not tell me the answer i'd be very appreciative as i joined this forum to learn and not to get answers.
Have no idea how to answer.
There's a couple ways you could do this. Is the object moving at all or is it standing still?
IF:
It is moving, set GPE equal to KE and isolate h.
It is stationary, just isolate h in the equation PE = mgh
To solve for h, you can divide both sides of the equation by mg, which will cancel out the mg on the right side and leave you with h.
