Potential energy and Conservative Force
The discussion centers on finding the potential energy function U from a given force vector F. The participants clarify that the correct approach involves integrating the components of the force vector, with the understanding that the constants a_x, a_y, and a_z should not be mistakenly integrated to yield quadratic terms. Instead, the potential energy U can be expressed as a function of x, y, and z, derived from the negative gradient of U. The final form of U incorporates separate functions for each variable, confirming that the initial shortcut method was mathematically incorrect. This emphasizes the importance of proper integration techniques in deriving potential energy from force.
Arman777
Insights Author
I have a force ##\vec{F} = a_x\vec{i}+2a_y\vec{j}+3a_z\vec{k}##. Find the potential
Lets suppose
And we know that ##\vec {F} = ∇U##
In this case I said that
##U_x=-\int F_xdx##
##U_y=-\int F_ydy##
##U_z=-\int F_zdz##
and then I said
##U= U_x+U_y+U_z##
Is this mathematically true ?
Normally I should have ##U(x,y,z) = -\int F_xdx## I guess..For example in this case I should have something like
##U(x,y,z) = -a_x^2+U(y,z)##
then I can say
##U(x,y,z) = \int (-a_x^2+ 2a_y)dy## etc. Which one is correct ?
Likes Mileto Graziano
Are ax etc. constants? If so, what are their integrals wrt x, y, z?
You can always check your answer using the differential equation you quoted.
##a## are constant. I find the answer its easy to find. I was asking about the mathematical part of it.Are both approaches are true ?
then I can say
You should never integrate a constant ##a_x## and get ##\frac12 a_x^2##. That's a common mistake.
Instead, you have:
##\vec{F} = (a_x, 2a_y, 3a_z) = - \vec{\nabla}U(x, y, z) = -(\frac{\partial U}{\partial x}, \frac{\partial U}{\partial y}, \frac{\partial U}{\partial z}) ##
If we start with ##-\frac{\partial U}{\partial x} = a_x##, then this gives:
##U(x, y, z) = -a_xx + f(y, z)##
Now we have:
##\frac{\partial U}{\partial y} = \frac{\partial f}{\partial y} = -2a_y##
Which leads to ##f(y, z) = -2a_yy + g(z)##
And, finally we have:
##\frac{\partial U}{\partial z} = \frac{dg}{dz} = -3a_z##
Which gives ##g(z) = -3a_zz + C##
Your first method is just a shortcut for this.
Instead, you have:
Now we have:
Yes sorry. Its a stupid mistake that I made...I see your point, thanks for clarifying it.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
