Potential Energy of an Electron in a Battery
An electron moving from the positive to the negative terminal of a 9V battery has a potential energy change calculated by the equation qV, resulting in 14.4 x 10^-19 J. The confusion arises over whether the electron gains or loses energy during this transition. Since the positive terminal is at a higher potential, a positive charge would lose energy, implying the electron gains energy. However, the discussion highlights that the movement of the electron contradicts conventional current flow and raises questions about the context of the movement. Clarification on the scenario is necessary to resolve the ambiguity regarding the electron's energy change.
erisedk
An electron moves from the positive to the negative terminal of a battery (9V). How much potential energy did it gain or lose?
Solving for the amount is basic. That's just qV = 14.4 * 10^-19 J
I'm not sure whether it will gain the energy or lose it.
I believe that since the positive terminal is at a higher potential, a positive charge would lose energy, and therefore, the electron will gain energy. But the answer at the back says that it would lose energy. I'm not sure what's wrong.
Wouldn't it take work to move an electron away from a positive charge?
erisedk said:
That's just qV
The more general relation is ##\Delta U=q \ \Delta V## where ##\Delta V## is the change in potential. If ##q## and ##\Delta V## have different signs, then ##\Delta U## is negative. If they have the same sign then ##\Delta U## is positive.
you are starting with an incorrect assumption
try again
No he isn't. The problem statement ask what happens if an electron moves from positive to negative. That occurs when a battery is being charged.
we shouldn't nitpick :wink:
he didn't say what if ... he stated it as a fact :wink:
this isn't likely to happen as it goes against the current flow
Noting that he hasn't stated if this is internal or external to the battery ... the norm being an external reference
battery charging also wasn't mentionedTo the OP
you need to write a clearer idea of what you are referring to, to stop the ambiguity :smile:D
The OP didn't state this, he's just trying to understand the statement he was given and answer a question about it. It makes no difference how the electron gets there. The positive terminal is at a potential of +9 volts relative to the negative terminal. An electron in the latter location has how much potential energy relative to an electron in the former location? That's an equivalent question.
Likes CWatters and erisedk
