Potential Energy of 2 Masses Connected by a String - Find Theta
The discussion focuses on finding the equilibrium point of two masses connected by a string in terms of the angle theta. Participants emphasize the need to express potential energy as a function of theta to identify its minimum. The vertical distances of the masses from a reference point are calculated using trigonometric functions, specifically L*cos(theta) for mass M1 and L*sin(theta) for mass M2. The potential energy is derived from the formula mgh, where h represents the vertical distance. The conversation concludes with a realization that determining these distances simplifies the problem significantly.
Parallel
A figure is attached.
A string with length L connects two beads with masses M1,M2.
what is the equilibrium point?(in terms of the angle theta,as in the figure)
well I know that I need to find the potential energy as a function of theta,and then find the minimum.
but I don't know how to express the potential energy in terms of theta
You know the distance between m1 and m2 is L. To get started, find the distances of m1 and m2 from the rightangle in terms of L and theta.
well this is easy
for m1 : l*cos(theta)
for m2 : l*sin(theta)
I can't see how this is helping me
(by the way,this is not homework,I'm doing extra problems from the book)
The potential energy of a mass = mgh where h is the vertical distance from some point.
From those lengths, finding the vertical distance of the masses below the right angle (using alpha) is also easy.
can't believe I didnt see it..really easy
