Potential Energy of Comet-Sun System: Calculate the Answer
The discussion focuses on calculating the gravitational potential energy of a comet in an elliptical orbit around the Sun, specifically at aphelion, where the distance is 50 AU. A user initially calculates the gravitational force but is reminded that the problem requires potential energy, not force. The correct approach involves using the gravitational potential energy formula, which is based on the distance from the Sun. The user is advised to reference the appropriate equations for gravitational potential energy to arrive at the correct solution. Understanding the distinction between force and energy is crucial for solving the problem accurately.
moondawg
A comet of mass 1.2x1010kg moves in an ellyptical orbit around the sun. It's distance from the Sun ranges between .5 AU and 50 AU. At aphelion what is the potential energy of the comet sun system?
AU=1.496x1011
F= ((G(1.99x1030)(1.2x1010))/(7.4807x1012)2=28462.67N... but that seems to small of a force, what am i doing wrong??
You found the force, but you were asked for the energy.
Look up the formula for gravitational potential energy if you need to.
Aphelion is point on the orbit with largest distance from the sun. Why do you plug numbers in force expression, when you need to find potential energy?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
