Potential/Kinetic Energy Problem
  • Thread starter Thread starter mhildreth
    Energy
A .2kg bouncy ball, launched vertically at 15 m/s, loses 10% of its kinetic energy with each bounce, retaining 90% after each impact. The initial kinetic energy can be calculated using the formula KE = 1/2 mv^2, which results in a specific energy value. To find the height after each bounce, potential energy (Ep = mgh) is compared to the kinetic energy at the peak of each bounce. After the first bounce, the height is determined by the retained energy, and subsequent heights can be calculated using the energy reduction factor of 0.9 for each bounce. The discussion emphasizes the relationship between kinetic and potential energy to solve the problem effectively.
mhildreth
A .2kg bouncy ball loses some of its kinetic energy when it collides with
the ground. Assuming it only maintains 90% of its energy after each bounce, how
high will it get for each of the first three bounces if it is initially launched
vertically at 15 m/s.
KE = 1/2 mv^2
KE(.9) = 1/2(.2)(15)^2
The KE you have there is the initial energy. What happens to it after the first bounce? What do you know about Kinetic and Potential energies that you can use to find the first height?
A) Find the first time and height of the ball after the projection upwards:
compare energies to find height:
mgh=mv^2/2 where: m cancelles out, v=15 and g =9.81, find h(height)
Alternativelly:
Find time for the ball to stop from:
V(t)=Vot-at where: a=g, Vo=15, V(t)=0
Having the time you can find the height it will reach:
S=Vot-((at)^2)/2) where: Vo=15, t=time from up(^), a=g.
Having the height use: Ep=mgh to find the potential energy of the ball.
After one bounce the energy will be equal to 90% of the initial mgh value, after two bounces the energy will be mgh*(0.9)^2 and after three mgh*(0.9)^3.
If anything needs to be explained more clearly, just post a reply.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
