Find Potential of Disk of Radius R, Charge Q w/ Equ 1
  • Thread starter Thread starter Miike012
    Potential
To find the electric potential of a disk with radius R and charge Q using equation 1, it is essential to first determine the electric field E generated by the disk. The potential can then be calculated using the line integral V(r) = -∫E·dx from infinity to the point of interest. The integration requires evaluating the contributions of the electric field from each segment of the disk. While integrating the electric field to find potential is valid, it is crucial to avoid confusing the calculations of potential with those of the electric field. Ultimately, the correct approach involves integrating the electric field over the appropriate limits to obtain the potential.
Miike012
I would like to know if there is a way of finding the Potential of a disk of radius R and charge Q with uniform charge distribution using Equ 1 instead of Equ 2?
Equ 1:
ΔV = -∫Edotdx rather than
Equ 2:
ΔV = ∫dUelec potential
For Equ 1 I'm guessing that the equation would be of the form...
ΔV = -∫∫Ecos(∏/2)dA = -∫∫EdA = -∫∫Edxdy
And
Limits of int (X-Direction): -√(R2 - y2) to √(R2 - y2)
Limits of int (Y-Direction): -√(R2 - x2) to √(R2 - x2)
And E would be the EField of a disk...
You can certainly integrate the E field to find the potential, but your attempt is wrong. It looks like you're confusing calculating the potential with calculating E.
To use equation 1, you need to have already found ##\vec{E}##, and you'd calculate the line integral along any path C that runs from infinity to the point ##\vec{r}##:
$$ V(\vec{r}) = -\int_C \vec{E}\cdot d\vec{x}.$$ To find ##\vec{E}##, you'd calculate the contribution from each piece of the disk to the electric field at some point in space, and then integrate over the entire disk.
To use equation 2, you take a similar approach as you do when calculating ##\vec{E}##. You calculate the contribution from each piece of the disk to the electric potential at some point in space, and then integrate over the entire disk. Calculating electric potential is a bit easier than calculating the field because the potential is a scalar quantity. You don't have to worry about summing vectors like you do when calculating the electric field.
So equation 1 would be..
V = -∫Ediskdx and integrate from xf = distance from point to disk and xi = ∞. is that correct?
Yes, basically.
