lailola said:
I know it may be strange but it's c, not v.
For a charged particle moving at the speed of light we can expect some singular behavior of the potentials and fields. I believe the following is true, but I welcome corrections.
In the case of a particle moving at light speed, the denominators of the Lienard-Wiechert potentials are just equal to the difference, Δz, in the z coordinate of the present location of the particle and the z coordinate of the observation point . (This is what you already essentially stated.) So, we have a singularity in the potentials when Δz = 0. The point on the trajectory corresponding to Δz = 0 is the point of closest approach of the particle to the observation point. Call this point of the trajectory O.
It is important to note that if the particle at the present time t has not yet made it to O, then
there does not exist a retarded time tr associated with this present time t. Thus, for a particle moving at the speed of light, you can only find retarded times for those present times for which the particle has already passed O!
So, the retarded Lienard-Wiechert potentials for a particle moving at light speed are only defined at the observation point for present times t for which the particle has already passed O.
If you use the potentials to find E and B for the times for which the potentials are defined, you will find E = 0 and B = 0 at those times. But, the retarded potentials cannot tell you what the fields are at the observation point at times when the particle has not yet made it to O or when the particle is at O.
You could use the so-called “advanced” Lienard-Wiechert potentials to find E and B for times when the particle has not yet made it to O. Again, I believe you would find E = B = 0. But these advanced potentials will be undefined at the instant the particle passes O and for all times after which the particle passes O. So even if we introduce both advanced and retarded potentials, we cannot get the fields at the observation point at the instant the particle passes O.
I think it would be better to begin with the speed v of the particle less than c. Then the retarded potentials are defined for all times and you can work out the E and B fields at the observation point for all times (as done in many textbooks). You can then take the limit of these fields as v approaches c. You will find in this limit that E = B = 0 at the observation point for all times except the instant when the particle passes O. At the instant the particle passes O, E and B at the observing point diverge to infinity as v approaches c.
All of this corresponds to the fact that the faster a charged particle moves at constant velocity, the stronger the fields become in a plane containing the particle and oriented perpendicular to the trajectory. For a particle moving at near light speed, the fields are essentially confined to this plane and have a very large magnitude.
