Power from one or both of 2 sources
  • Thread starter Thread starter doowruc
    Power Sources
The discussion centers on adding a new interior light to a car that can be powered by either the headlights or existing interior lights without interference. Participants suggest using power diodes to prevent the two circuits from affecting each other, ensuring that the new light operates correctly. Concerns are raised about potential current or voltage issues if both sources are live, but it is clarified that the new light will only draw the current it needs. Additionally, there is a note on the evolution of interior light circuits, emphasizing the importance of checking the specific wiring in modern vehicles. The original poster expresses confidence in following the provided instructions for their specific car model.
doowruc
Hi all,
Apologies if this is the wrong place to post this but I can see lots of similar questions on this forum which aren't a 100% match for my question.
I want to add a new interior light to my car.
I want it to be on either when the headlights are on (power from the illumination circuit of the radio) or when the existing interior lights are on. It is possible that both could be on at the same time.
Both sources are (I assume) +12v
The new light will be grounded to the car chassis via the cig lighter -ve.
Is this possible? How do I ensure that the 2 power sources do not affect each other? (i.e. I don't want the existing interior light coming on when I switch the headlights on!)
TIA
Hi doowruc! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
One power diode in series with each lead from each source should work.
Thanks for the welcome!
So, would it be 2 of these that I need?
http://www.maplin.co.uk/1500w-unidirectional-transient-voltage-suppressor-diodes-46416
And is this the basic circuit?
What would happen if both were live? would the new light then get too much current or voltage?
Yes, that looks like the arrangement. How many watts or amps is the bulb?
Probably use these: http://www.maplin.co.uk/3a-silicon-rectifiers-46405
No, it will draw just as much current it requires. Nothing wrong will happen.
(As a side note: Calculating the current shares of the lines, when both line is live, is a difficult and quite unpredictable thing. Depends upon Diode Imperfection and Line resistances.)
You might check something on the interior light before getting too far along.
In old days they worked by completing a circuit to chassis, on side of bulb opposite the battery. The little buttom in doorjamb made that connection.
On those automobiles your interior light would have 12V on both sides when OFF and on one side only when ON.
Nowadays they are controlled by the computer and i don't know which wire the computer switches, could be either the "hot" or the "return".
The button in doorjamb apprises computer there's a door open and computer decides whether to light light and for how long.
So get your meter and check that interior light socket to see which side changes state when it comes "on".
old jim
old jim
Thanks Jim. The kit I am buying comes with specific instructions for my car and wiring into the interior light circuit so I hope that this will be covered!
