How Much Power is Generated by a Turbine Rotating at 40 RPM?
  • Thread starter Thread starter ourjungle
    Power Turbine
The discussion centers on calculating the power generated by a turbine rotating at 40 RPM with a force of 5 kg applied at a distance of 0.5 m from the center, using a weight dropped from a height of 50 m. The original poster seeks guidance on how to approach this problem as part of their coursework. Participants inquire about the course details and available learning resources, expressing concern over the lack of provided materials. The conversation highlights the need for clearer educational support in understanding the physics involved. Overall, the thread emphasizes the importance of proper guidance in academic settings.
ourjungle
Hi
how much power is generated by moving a turbine in 40rpm by applying a force of 5kg on the blade at distance of 0.5m from center of rotar ...(the weight is drooped from height of 50m on
the blade )...
thanks
ourjungle said:
Hi
the blade )...
thanks
Is this homework/coursework? What is the application?
Hi
It is included in the course, and I am unable to understand as how to proceed. Can you please guide me. Thanks
ourjungle said:
Hi
What is the course? Which university? Why have they not given you the learning materials to figure this out? What other learning resources have you tried (google, wikipedia. etc.)?
