2025 Award
- 17,295
- 10,756
Double the energy is a change of 10*Log(2) = 3dB. I think you were expecting doubling the dB which is squaring the SE?flowwolf said:I remember reading that in more than one document, those showed that when doing precisely, the 2nd layer improves SE by some (30 or so) dB, but it will be less than double.
According to your ref; Kistenmacher and Schwab, 1996. IEEE. Page 351.
My statement is shown to be true for conductive non-magnetic materials, for Cu see fig. 12.
The effectiveness increases with frequency. Note the plot there assumes the same total mass of material.
My statement is false for magnetic resistive screen materials. See fig 13. Which is what you expect from ferrite slabs that are designed to allow EM propagation between the magnetic grains.
Your reference, the Bahadorzadeh, Moghaddasi and Attari, 2008, paper, appears to be discussing cascaded apertures in the wall of a cavity. Figure 2 shows two walls give about a 12dB advantage over one. That is significantly better than a factor of two and supports my suggestion that the same mass distributed amongst several walls is better than one thick wall. The paper goes on to show increased wall separation increases screening.
Resonant cavities need coupling to be part of the circuit. A 100mm thick timber stud wall supporting and separating two conductive sheets will not support a significant resonance. Galvanised steel is cheaper than copper and can be easily soldered along the seams.flowwolf said:btw. Wouldn't a two-layered wall cause resonances and worsen SE at specific frequencies?
