Power of a bicycle accelerating up a slope.
The discussion revolves around a physics problem involving a cyclist accelerating up a slope. The original poster presents a scenario where a cyclist accelerates at a constant rate up a 15-degree slope, covering a distance of 30 meters in one minute, with a total mass of 80 kg. The goal is to calculate the power required for this scenario while neglecting air resistance and drag.
  • The original poster attempts to use force and power formulas to calculate the required power, while some participants question the distance covered in the given time and the correctness of the work calculation. Others suggest that the work should include changes in potential and kinetic energy.
Participants are actively engaging with the problem, providing corrections and alternative perspectives. Some suggest simplifying the problem to constant velocity or adjusting parameters to achieve more realistic outcomes. There is an ongoing exploration of the assumptions made in the original scenario.
Participants note that the original scenario may not be realistic, as the calculated speeds and power outputs exceed typical cyclist capabilities. There is also a mention of the need for more realistic input values to align with practical cycling scenarios.
Kraken_Head
No template because originally posted in wrong thread
Hello everyone :alien:
I have been assigned to create a physics problem involving bicycles. I thought up the following, but I had questions regarding if it was properly made / worked out.
A cyclist is accelerating constantly up a slope at 1 m/s ^-2 The slope is at a 15 degree angle and is 30 m long. It takes the cyclist 1 minute to reach the end of the slope. The combined mass of the cyclist and the bicycle is 80 kg. How much power is needed to make this possible ? (Neglect air resistance and drag)
I was thinking of using the formula: F = mg sin θ + ma to calculate the force needed to go up the slope, and then incorporating the found value of F into the formula: P = work / time = ( F x d ) / t to find the amount power needed to complete this task. The working out looks like this:
P = ( ( mg sin θ + ma ) x d ) / t
P = ( (( 80 x 9.81 ) sin ( 15 ) + ( 80 x 1 )) 30 ) / 60
P = 141.6 W
Is this correct ? Are there any variables of e.g. vectors, forces, etc. that I have forgotten to include in this calculation? or am I over complicating things ?
Thank you very much !
How do you know that after 1 minute, the bicycle only covers 30 m? I get 1800 m (almost 2 km). The work is also calculated incorrectly. The work is equal to the change in potential energy plus the change in kinetic energy. Also, the power is not constant. The work divided by the time is equal to the average power.
Thank you for making me notice that ! At the time, I was just trying to make up some figures off the top of my head, but now I realize I had to use the formula:
d = 1/2 a t^2 to figure out the distance traveled at that acceleration.
I also appreciate the correction on the work done formula. If I'm correct, it should look like this now :
W = Δ Ep + Δ Ek
____________________________________________________________________________________________
ΔEp = mg Δh
= ( 80 ) ( 9.81 ) Δ( length of X = 465.9 m - see right angled triangle )
= 319915.8 J
SOH
X = sin(15) x 1800 = 465.9 m
ΔEk = Ek f - Ek i
= (1/2 m (v final)^2) - (1/2 m (v initial)^2)
v initial = 0
v final = (v initial) + at = (0) + (1)(60) = 60 m.s^-1
= (1/2 (80) (60)^2) - (1/2 (80) (0)^2)
= 144000 J
W = (319915.8) + (144000)
= 463,915 .8 J
Average Power = work / time
Av P = ( 463,915.8) / 60
= 7731.9 W
However, upon seeing the final answer I can't help but feel like I miscalculated something ( I suspect an error when calculating the change in kinetic energy, or maybe the scenario simply isn't realistic ) because the magnitude of the answer - I feel - is too big for a cyclist.
Thank you for your feedback !
The scenario isn't realistic, cyclists don't cycle at over 200km/hr (60m/s) and can't accelerate at a constant rate. They are close enough to constant power device, like a car. A quick google says an elite cyclist can maintain ~500W over an hour, ~1,200W in short bursts.
Thank you !
Perhaps simplify the problem by making it constant velocity rather than constant acceleration? or would that be too easy?
Perhaps turn the problem on it's head. The max power a cyclist can generate is 300W, how fast can he go up the slope?
How about a problem involving a unicyclist and working out the angle he must lean forwards or something like that?
You can still use the problem as stated, but you have some input numbers that you can play with to make the problem more realistic: the angle, the time, the acceleration. Play around with these until you get a more realistic power value.
Thats a very good idea! Thanks for helping me out.
Thank you! Ill toy around with the equation a bit
  • · Replies 73 ·
  • · Replies 18 ·
