Power Series - Can someone me understand them?
NINHARDCOREFAN
I don't understand how to get the inteveral of convergence from a problem:
for example:
infinity
_
/ -(1)^n(x-2)^n/(n*4^n)
_
n=1
I know you have to use ratio test and it comes out to:
|x-2|/4
The textbook says the series converges when |x-2|<4. How did they come to this conclusion? How do you find c? the answer was c=2. The series converges when -2<x<6 and diverges if either x<-2 or x>6. Can someone explain this also? Thanks
\sum_{n=1}^\infty \frac{((-1)^n)(x-2)^n}{n4^n} converges when a_n < 1 , so |x-2|/4 < 1 => |x-2|< 4.
|x-2| < 4 means that for -2 < x < 6, the series converges. plug x=-2 into the series & see that the series converges @ x=-2. plug x=6 into the series & it converges there also. so the interval of convergence is [-2, 6]
hmm...
You just listed the facts and didn't explain them explicitly... anyway I understood most of the stuff through doing the problems. But I still don't understand one thing, when you plug in the x how do you find the limit when n is at infinity, I'm getting confused because of n being the power...
When you plugged in x=2 how do you solve for it?
|x-2|/4
Right.
They came to it by recognizing that under the ratio test a series converges absolutely if the limit as n goes to infinity of |an+1/an| is less than one. So you get:
|x-2|/4<1
or...
|x-2|<4
When you work the inequality above into the form:
|x-c|<R,
then c is the center of the series and R is the radius of convergence.
Use the definition of the absolute value.
|x-2|<4
-4<(x-2)<4
-2<x<6
Now that doesnt' tell you the endpoint convergence. You still have to test for that. So you plug x=-2 and x=6 into your power series (one at a time, of course) and you see if the resultant infinite series converge or diverge. That will tell you which inequality to put an "equal" sign under, if any.
Thanks. But you didn't answer my main question, how do I solve the series after plugging in the x value (into the series)?
Have you not studied infinite series??
If you plug in x=-2, you get:
\sum_{n=1}^\infty \frac{((-1)^n)(-2-2)^n}{n4^n}
\sum_{n=1}^\infty \frac{((-1)^n)(-4)^n}{n4^n}
\sum_{n=1}^\infty \frac{((-1)^n)(-1)^n4^n}{n4^n}
\sum_{n=1}^\infty \frac{1}{n}
...which diverges by the integral test.
I'll leave it to you to plug in and test the series at x=6.
doh! :frown: it's (x-2)^n not (x-2). just ignore my stuff...
There isn't necessarily an expression for the result of a sum. People are probably working on a nice expression for
\sum_{i=1}^{\infty} \frac{1}{n^3}
right now.
All this problem is asking for is convergence, so:
The ratio between the n^{th} and (n+1)^{th} terms is
\frac{n+1}{n} \frac{(-1)(x-2)}{4}
in the limit that turns into
\frac{(-1)(x-2)}{4}
and the ratio must be less than one for the series to converge, so
\left|\frac{(-1)(x-2)}{4}\right| &lt; 1
\left|(x-2)\right| &lt; 4
-2 &lt; x &lt; 6
