Power Series Solution of y''+(x^2)y=0: Is it Possible?
sigma128
y''+(x^2)y = 0
I tried to solve this problem using Power Series.But i can't make the solution in the form of series that have only two constants(a0,a1)that is, there are a0,a1, a2, a3. So i just wonder how can i make it has two constants.
You would have to show us how you got 4 different constants in order to show where the error occurred.
sigma128 said:
y''+(x^2)y = 0
Do you need to get a series solution? If not, if you substitue y'' = r', it seems it becomes a simple separation of variables problem.
how can i post some method or my idea solving the problem.what programm needed to do that
PS to..EugP , i want the series solution because my teacher want :smile:
I was hoping you wouldn't, because I haven't learned series solutions yet :frown:
So, sorry but I can't help.
You don't need any program to show us your work, just use LaTeX:
https://www.physicsforums.com/misc/howtolatex.pdf
Good luck!
thank you very much
Reduction of order won't work, as you have the second derivative and the function.
To solve it with power series, you must take y(x)=\sum_0^\infty a_n x^n, so
y'(x)=\sum_{n=1}^\infty n a_n x^{n-1},
y''(x)=\sum_{n=2}^\infty n (n-1) a_n x^{n-2}.
If you plug it in the ode, you'll obtain the following equation:
\sum_{n=2}^\infty n (n-1) a_n x^{n-2}+\sum_{n=0}^\infty a_n x^{n+2}=0,
therefore, you'll have to change the index in the sums in order to have the same powers of x in both sums. To do that, take n=m+4 in the first sum. The equation becomes
\sum_{m=-2}^\infty (m+4) (m+3) a_{m+4} x^{m+2} + \sum_{n=0}^\infty a_n x^{n+2}=0.
Writing down the first two terms of the left sum and factorizing, we have
2 a_2+6 a_3 x + \sum_{n=0}^\infty [(n+4) (n+3) a_{n+4}+a_n]x^{n+2} =0.
The only way the equation is going to be fullfilled is that a_2=a_3=0, since there is no constants or first order powers under the sum sign. Hence,
\sum_{n=0}^\infty [(n+4) (n+3) a_{n+4}+a_n]x^{n+2} =0,
wich gives the recurrence relation
a_{n+4}=-\frac{a_n}{(n+4)(n+3)}.
Now, I've already done the hard part. You have to take it from here. To construct the first solution take a_0=1,a_1=0. To construct the second solution take a_0=0,a_1=1 (why?). From the relationship above, it's easy to see that the condition a_2=a_3=0, makes a hole bunch of terms to be zero, so you only have to calculate two general terms.
Good luck.
oh i see,thank you.but u make little mistake after u take n=m+4 ,right? please check it.now i try to think why a0=0,a1=1 and vice versa
What mistake? Could you point it out please?
hmm,now the mistake disappear!.Last time i saw that after u take n=m+4 the first sum u wrote the power of x =x^m which was wrong! but now it is x^m+2 ,that's right.i guess u may edit it already or my sight was wrong at that time.Anyway,thank you for your work.
No problem :)
i don't understand why you can take a0=0,a1=1 and vice versa
You can take them to be any thing you want- they will be the constants you get integrating. Taking them to be 1 and 0 (and then 0 and 1) means you can just multiply the solutions you get by C1 and C2 to get the general solution.
It would help a lot if we could see what you know (or think you know) about this kind of problem. Is there any reason why you won't post your original solution to the problem as the first response asked?
just look at it. it says y'' is x^2 times y. how often does the degree of a derivative go up instead of down?
well at least that says it is not a polynomial. but doesn't it also say it isn't a powers eries? i mean look at the lowest degree term. multiplying it by x^2 is quite different from differentiating it twice.
try a laurent series. does anything help?
just set y = a0 + a1X + a2X^2 +..., multiply by -x^2
and set equal to y''.
i guess that's what you did. but what happened? what puzzling thing occurred?
I normally refer to Michael D. Greenberg, Advanced Engineering Mathematics for solving mathematical problem. It is suggested that we use the following change of variables
t=x^2/2 , u =x^(-1/2)y
to convert y''+(x^2)y = 0 into a Bessel equation.
The solution will be
y = x^(1/2) ( A J_1/4(x^2/2) + B J_-1/4(x^2/2) )
where A and B are constants and
J_1/4 (t) is the Bessel function of the first kind, of order 1/4.
