Power Supply Problem: 19V 3A Laptop Charger + Solenoid
The discussion centers on using a 19V 3A laptop charger to power a solenoid, where the user observed a voltage drop and fluctuating AC readings when a load was connected. It was noted that the charger may be going into current limit due to an improper load, suggesting a need for a load of approximately 6.3 Ohms to maintain proper function. Attempts to use a 6 Ohm resistor resulted in the solenoid ceasing to function, indicating that the load should be the solenoid itself rather than a resistor in series. Participants emphasized understanding the relationship between amp-turns and magnetic field strength for effective solenoid operation. Proper load matching is crucial for the charger to deliver stable DC output while under load.
Anugrah_kora
I've got an old laptop charger 19v 3A for my solenoid.
I used a multimeter to check the charger without and with load. I used a solenoid of insulated 22gauge of approx 150 turns as the load. On my first try without any load, it gave 20v DC on the multimeter.
When I connected the load and connected the multimeter ,it gave values on AC part fluctuating back and forth from 0-1.5v . Can anyone help me out in this? Is there anyway to get DC out of it while on load ?
You are shorting out its output, so it is in current limit until you remove the short.
You need to put a load of about 19V/3A = 6.3 Ohms on it to keep it out of current limit.
I tried 6ohms ( I don't remember correctly,but it's close to 6ohms) and the solenoid literally ceased to function :(
What wattage resistor did you use? I^2 * R = 54W, so you would have needed a pretty big power resistor...
#22 is 16 milliohms per foot.
How many feet of #22 would it take to make six ohms ?
On your solenoid's diameter, how many turns would that be ?
Do you understand the relation between amp-turns and magnetic field strength ?
You might look that up . Train your search engine - it wants to please .
Likes berkeman
not surprised ... your LOAD, the coil, needs to be around 6 Ohms ... not a 6Ohm resistor in series with it :smile:Dave
Likes berkeman
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
