Power to overcome bearings resistance
  • Thread starter Thread starter Sunfire
    Power Resistance
Estimating the power required to overcome the resistance of NSK Super Precision Angular Contact Ball Bearings involves understanding dynamic torque, which is influenced by load and speed. The formula provided for dynamic torque includes variables such as a dimensionless factor, kinematic viscosity, speed, and pitch circle diameter. Concerns were raised about the dimensional analysis of the formula, particularly the absence of mass units on the right-hand side, suggesting a potential error. Clarification is needed on how the speed variable relates to mass. Accurate calculations are essential for determining the power needed at specific RPMs.
Sunfire
Hello,
I have a pair of bearings (NSK Super Precision Angular Contact Ball Bearings) and was wondering whether I would be able to estimate the power it takes to overcome the bearings resistance when the shaft spins with some given rpm.
Are you aware if this is possible to estimate. Thanks!
Download the product catalog from the NSK website. That has the technical data to answer the question.
Here is the catalog info...
... and the formula using the factor f_0 is in Part 5 Section 6.
Likes 1 person
Thank you :smile:
The dynamic torque is given by a load term and a speed term.
The speed term is:
##M_v = f_0 (v_0 n)^{2/3} d_m^3##, but its dimensional analysis has left me wondering.
##M_v## - dynamic torque, dimension [N.m]
##f_0## - some factor, dimensionless
##v_0## - kinematic viscosity, [##m^2##/s]
##n## - speed, [?]
##d_m## - pitch circle diameter of rolling element, [m]
Lhs requires a [kg] to appear somewhere in the Rhs. Probably something is amiss with the above expression. I cannot imagine [kg] has anything to do with the "speed" ##n##?
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
