Effect of Load Torque on Belt Tension and Power Transmission
The discussion revolves around a homework problem involving the effect of load torque on belt tension and power transmission in a pulley system. Participants explore calculations related to power transmission, belt tension, and the impact of various factors on these parameters.
  • Homework-related
  • One participant calculates the actual power transmitted to the second pulley and provides a detailed solution for part (a) of the homework.
  • Another participant confirms the correctness of the calculation for part (a).
  • Several participants express uncertainty about how to approach part (b), with one asking for guidance on solving it.
  • A participant proposes an equation involving forces and friction to solve part (b), equating F1 to 4000 N.
  • There is a question regarding the source of a specific formula used in the calculations, with one participant stating it is from their learning material.
  • Another participant seeks clarification on the application of the formula and the meaning of the variable θ, which is identified as the angle of lap of the belt around the pulley.
  • One participant expresses a desire for pointers on how to approach part (d) of the problem, indicating ongoing uncertainty in the discussion.
Participants generally agree on the calculations for part (a), but there is no consensus on the approach to parts (b) and (d), with multiple competing views and uncertainties remaining in the discussion.
Some participants express confusion regarding the application of specific formulas and the assumptions behind them, indicating potential limitations in understanding the problem fully.
Students studying mechanics, particularly those interested in power transmission systems and belt dynamics, may find this discussion relevant.
oxon88
I have this self study question, can anyone provide some guidance?...
A pulley 150 mm diameter is driven directly by an electric motor at 250 revs min–1. A V-belt is used to transmit power from this pulley to a second pulley 400 mm diameter against a load of 200 Nm.
The distance between the centre of the pulleys is 600 mm, the included angle of the pulley groove = 40°, the coefficient of friction between the belt and pulley is 0.4 and the ultimate strength of the belt is 8 kN.
(a) Calculate the actual power transmitted to the second pulley.
(b) Calculate the power which can be transmitted if the maximum tension in the belt is limited to half of the ultimate strength of the belt.
(c) What would be the effect of the following factors on the maximum power which can be transmitted (give reasons for your answer):
(i) increasing the coefficient of friction
(ii) increasing the included angle of the pulley groove.
(d) What would be the effect on the following if the load torque is increased and the speed maintains constant (give reasons for your answer):
(i) the tension in the tight side of the belt
(ii) the tension in the slack side of the belt
(iii) the power transmitted.
P(t) = τ.ω (power is the product of the torque τ and angular velocity ω)
a)
Driver speed = 250 revs min-1 = 25pi/3 rad s-1 = 26.18 rad s-1
Driven Speed (angular Velocity) = (25pi/3) * (0.075/0.2) = 25pi/8 rad s-1 = 9.817 rad s-1
Power dissipated at pulley 2 = (25pi/8) * 200 = 625*pi W
= 9.817 * 200 = 1963.4 W = 1.9634 kW
Part a) looks right.
Where is part b?
can anyone advise on how i should solve part b?
You should try it first.
really struggling with this.
do i need to equate F1 to 4000n?
ok so how does this look for part B?F1 equated to 4000n
F1 / F2 = e^((μ*θ/(sin(α))
4000 / F2 = e^((0.4*2.722) / (sin(20))
4000 / F2 = 24.13
F2 = 165.77
T = (F1 - F2) * r
T = (4000 - 165.77) * 0.075m
T = 287.56724P = 387.56725 * 8.333*∏ = 7524.5 W
Where did you get this formula?
its one of the given formula in my learning material.
does my answer look reasonable?
How did you know to apply that formula? What is θ?
its the angle of lap of belt round pulley (radians)
Trying to attempt part d) ...anybody got any pointers?
  • · Replies 45 ·
26K
  • · Replies 20 ·
21K
