Pozitron-Electron interaction(anihilation)
  • Thread starter Thread starter pop_ianosd
The discussion centers on the conservation of energy in positron-electron annihilation, specifically regarding the energy of the resulting photons. One viewpoint suggests that the equation should be 2m0c2 + T = 2ε + Ek, arguing that the atom becomes ionized after the electron vanishes, thus increasing its energy by Ek. The opposing view presents the equation as 2m0c2 + T + Ek = 2ε, implying that Ek should be added to the total energy before annihilation. The crux of the debate lies in whether Ek, defined as positive, should be subtracted or added in the conservation equation. This disagreement highlights the importance of correctly accounting for binding energy in energy conservation principles.
pop_ianosd
A given pozitron with T kinetic energy is approaching an electron bound to a hard nucleus(in the K energy level, and the ionization energy for this level, Ek(>0), is given).
The energy of the two resulting photons is to be determined.
Conservation of energy.
So I wrote the conservation of energy as follows:
2m0c2 + T = 2ε + Ek ( ε is the energy of one photon )
Let me explain my way of thinking: After the anihilation, the electron has vanished, so the atom has become a ion(so it's energy has increased by Ek).
However, the proposers of the problem consider the conservation of energy as follows:
2m0c2 + T + Ek = 2ε;
So who is right?
If Ek is defined to be positive, it should be subtracted on the left side (or added on the right side).
Otherwise you can violate energy conservation: Take a free electron, let it get caught by a nucleus (emitting energy). Add a free positron, and get more than 2*511keV as energy => you gained the binding energy two times.
