ChrisVer
- 464
Another question...
What does [un]prescaled trigger refer to? what is being scaled [and pre- to what]?
A prescaled trigger is a type of trigger used in particle physics experiments to filter out unimportant events and save computing resources. It works by only allowing a certain percentage of detected events to be recorded and analyzed, while discarding the rest.
A prescaled trigger works by using a random number generator to select a fraction of events to be saved and analyzed. This fraction, or "prescale factor", is determined by the experimenter and can be adjusted depending on the needs of the experiment.
A prescaled trigger is used to reduce the amount of data that needs to be processed and stored, as particle physics experiments can produce a large number of events. By discarding a portion of events, computing resources can be used more efficiently, allowing for faster data analysis.
The prescale factor is determined based on the expected rate of events in the experiment. It is typically chosen to be large enough to reduce the data to a manageable level, but small enough to still capture important events. The factor may also be adjusted during the experiment if necessary.
The main advantage of a prescaled trigger is that it allows for more efficient use of computing resources and faster data analysis. However, a potential disadvantage is that it may discard important events or bias the data if the prescale factor is not chosen carefully.
