Preserving Snow from January to June: The Science & Tactics
  • Thread starter Thread starter Wrongfellow
    Science
Preserving snow from January to June is challenging due to physical processes that cause it to turn into ice. Sealing snow in a plastic bag may not prevent moisture loss, especially if the freezer goes through defrost cycles, causing slight melting and refreezing. Even at temperatures below 0°C, sublimation and condensation can lead to the formation of solid ice rather than fluffy snow. To achieve a snow-like texture for summer use, blending the ice before throwing it is suggested. Effective preservation of snow requires careful management of temperature and moisture conditions.
Wrongfellow
When the last snow fell I picked some up and put it in the freezer,
sealed in a plastic bag to keep moisture out. I hoped I'd be able to
get it out in the summer and throw a snowball at someone on the
hottest day of the year.
It didn't work. After a few months in the freezer the snow turned to
ice, and throwing a lump of ice at somebody isn't funny.
Basically I'd like to be able to preserve a handful of snow from
January until June, and be able to get it out again in the same fluffy
condition it was in when I picked it up. How can I achieve this?
What physical processes are responsible for turning the snow to ice?
I thought I'd protected it against moisture from the air, by sealing
the snow in a plastic "zip lock" bag. Maybe my freezer isn't cold
enough? How cold does it need to be?
The problem most likely arises from your freezer going through defrosting cycles. It gets just warm enough for the snow to melt slightly but not enough for things kept in the freezer to thaw. Then when the freezer goes back into normal mode, the slightly wet snow refreezes into a solid mass.
There's a potential problem even if the freezer doesn't ever get above 0°C. Equilibrium between the frozen snow and the water vapor in the bag means that ice will continually sublimate and condense while the snowball sits in the freezer. And there's no guarantee that the new ice crystals will form as light, fluffy snowflakes. In fact, it seems more likely that they'll deposit layers of solid ice.
Put it in a blender when you want to toss it at someone.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
