Pressure Equalization of X & Y Gas Bottles
The problem involves two gas bottles, X and Y, connected by a tube with a closed valve. Bottle X has a volume of 2V and contains hydrogen at pressure p, while bottle Y has a volume of V and contains hydrogen at pressure 2p. The discussion centers around determining the new gas pressure after opening the valve, assuming constant temperature throughout the process.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore the application of the ideal gas law and Boyle's law to analyze the situation before and after the valve is opened. There are attempts to calculate the number of moles in each container and how they relate to the pressures and volumes involved. Some participants question the validity of using Boyle's law in this context.
The discussion is ongoing, with various interpretations being explored. Some participants have provided calculations and reasoning, while others have raised questions about the assumptions made, particularly regarding the application of gas laws. There is no explicit consensus on the correct approach or outcome yet.
Participants are working under the assumption that temperature remains constant throughout the process, which is a critical factor in their calculations. There is also a focus on the relationship between pressure, volume, and the number of moles of gas in the system.
zanyzoya
X and Y are two gas bottles that are connected by a tube that has negligible volume compared with the volume of each bottle. There is a valve in the tube that is initially closed. X has a volume of 2V and contains hydrogen at a pressure of p, Y has a volume V and contains hydrogen at a pressure of 2p. X and Y are initially at the same temperature. The valve between the two bottles is now opened, Assuming that there is no change in temperature, what is the new gas pressure?
pV=nRT
rearranging R = pV/nT so
(PxVx)/(Tx nx) = (PyVy)/(Ty ny)
T's cancel so
(PxVx)/nx = (pY Vy)/ny
Vx = 2Vy and Px = 1/2 Py so...
1/2Py x 2Vy / nx = Py Vy / ny
PyVy/nx = PyVy/ny
hence nx = ny
therefore PxVx/Tx = PyVy/Ty
temperatures cancel so
PxVx = PyVy
1/2 Pyx 2Vy = PyVy
PyVy = Py Vy ?!?
You want to use the gas law, apparently before and after opening. How does that show in your working ?
If T is the temperature, how many moles are present in each container to begin with (in terms of p, V, and T)?
2PV/RT moles in each container. Therefore a total number of 4PV/RT moles in the system.
Hence After opening
3P2= 4P
I.e. P2= 4/3 P
Am I right?
Hence After opening
3P2= 4P
I.e. P2= 4/3 P
Am I right?
You know you are.
Thanks for the help
Just got a question about this question . I'm using Boyle's law for this but am getting the new pressure as 2p/3 ?
Both bottles are at the same temperature and so will both have same constants of 2Vp.
So once the valve is opened total volume is now 3V however there is no change in temperature so boyle's constant will be the same . Equating this with P being new pressure : 3VP=2Vp ... P=2p/3 ? Is my theory wrong here?
This is not correct. The OP analyzed the problem correctly in post #4. What made you think you could use Boyle's law on this?
because bottle X:p,2V . Y:2p, V . Both x and y at same temperature , so constant for both is 2Vp . When valve opened new volume is 3V but the constant stays the same because temperature stays the same no ?
The "constant" is proportional to the number of moles (as in PV = nRT). 1 mole of gas will not have the same value of PV as 10 moles.
Initial number of moles = ##\frac{p(2V)}{RT}+\frac{(2p)V}{RT}=\frac{4pV}{RT}##
Final number of moles = ##\frac{P(3V)}{RT}##
Initial number of moles = Final number of moles
10K
11K
