Is Pressure Constant Along the Horizontal Axis in a Fluid Element?
  • Thread starter Thread starter Fritz
    Pressure
Pressure remains constant along the horizontal x-axis in a fluid element, while it varies with depth along the vertical z-axis, described by the equation dP/dz = -density.g. The integral of this equation, p(z) - p(z1) = -density.g(z-z1), holds true only if density is constant. Incompressibility implies that the density of a fluid particle is constant, but the density field can vary over time due to different particles occupying the same spatial point. Therefore, while individual fluid particles maintain constant density, the overall density field may change unless all particles share the same density. Understanding these concepts is crucial for analyzing fluid behavior in continuum mechanics.
Fritz
If you have a rectangular fluid element verticle z-axis and a horizontal x-axis, pressure is constant along the x=axis, but p=f(z) along the z-axis.
If \frac{dP}{dz}=-density.g
is the integral of \frac{dP}{dz} equal to p(z) - p(z1) = -density.g(z-z1)?
Mathematics news on Phys.org
That would be true only if the denisity is constant. Also, be careful with your signs on the right hand side.
Assume it is a liquid and therefore (practically) incompressible.
Incompressibility does not entail that the density field is constant.
Density = mass / volume.
If the volume doesn't change (incompressible), surely the mass wouldn't change?
In continuum mechanics, we use density FIELDS, rather than particle densities.
Incompressibility entails that the density of A FLUID PARTICLE remains constant; but because the individual fluid particles may jump around in space, it does not follow that the density FIELD is constant.
The field measures the density of whatever particle happens to be AT A FIXED POINT IN SPACE; since it may be different fluid particles which occupy that point at DIFFERENT TIMES, the density field, evaluated at that point may change in time.
If you suppose in addition that all particles has the SAME density, then the density field will be constant.
Get it?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
