Principal frequencies of a Waveform
The discussion revolves around identifying the principal frequencies in a current waveform and calculating total harmonic distortion (THD) based on those frequencies. Participants explore the definitions and calculations related to harmonic analysis, including the use of FFT and the implications of different frequency components.
  • Homework-related
  • One participant identifies principal frequencies at 52Hz, 246Hz, and 351Hz, questioning the definition of "principal frequency."
  • Another participant suggests that principal frequencies may correspond to the peaks in the spectrum drawing.
  • There is confusion regarding the calculation of total harmonic distortion (THD), with participants discussing the correct interpretation of the formula and the variables involved.
  • Some participants assert that the principal frequency is the largest peak, while others suggest it is the fundamental frequency with distortion frequencies being the others.
  • Disagreement arises over the correct application of the THD formula, particularly regarding the use of sum of squares versus the square of the sum.
  • Participants express uncertainty about the meaning of "nth harmonic" and how to apply it in calculations.
  • One participant mentions simulating the original waveform using LT spice and discusses the challenges of replicating the waveform through Fourier synthesis.
Participants do not reach a consensus on the definition of principal frequencies or the correct method for calculating total harmonic distortion. Multiple competing views on these topics remain, with ongoing debate about the appropriate formulas and interpretations.
There are limitations in the discussion regarding the assumptions made about the waveform and the nature of the data provided. Some participants express uncertainty about the interpretation of the spectral data and the implications for THD calculations.
This discussion may be useful for students and practitioners interested in waveform analysis, harmonic distortion calculations, and the application of Fourier analysis in electrical engineering contexts.
  • #31
his_tonyness said:
Ok, If i produce a simulation over 57ms or 1/T with the 3 principals at their orignal not square values that would be a more accurate synthesis?
No, see my next post. Looks like my mistake.
  • #32
OK I ran the excel data anylis Fourier program and finally (my last column) got your magnitudes as depicted on your graph. So it looks like your sample were I2, not I, which I wonder how you (or they) did that. In other words, you were right to show your generators as I2 instead of I in your simulation.
My excel Fourier transform run is attached. Obviously your spreadsheet used the same excel algorithm, the one from the data analysis package. I hope the upload worked. If you get a strange spreadsheet let me know.
  • #33
I'm currently working through this and I noticed that the coefficients (bn and an) in one of the attached spreadsheets is incorrect. The Fourier components should be divided by N (using IMDIV) before either multiplying by 2xn for an (using real part) and -2yn for bn (using imaginary part).
Regards
  • #34
Regards
Correct. I looked at "H2" and assumed the rest was all "IMDIV'ed", my mistake. Unfortunately I don't know how to perform IMDIV on multiple cells and I am not doing it one by one for 1024 cells! Multiplying the real and imaginary parts separately is a pain too to extract sine and cosine coefficients.
  • #35
All you need to do is carry the formula out for one cell, then highlight the result cell (where you have your =) and drag it down for each cell (you will see a little plus sign) this will then carry out the formulas for every cell/result. Very straight forward to do.
Any problem and I will explain some more.
  • #36
here's my updated worksheet with the A and B coefficients calculated (cos and sin resp.)
  • #37
Re- Uploaded the file showing the actual An and Bn values. You forgot to multiply An by 2 and Bn by - 2.
  • #38
I think there are more problems.
If the data is samples of I2, which gives the graph you posted, then there can be no real and imaginary components.
So this time I will assume that the samples are I. I'll work on this and send it for what it's worth.
  • #39
I'm wondering if the coefficients calculated by excel (Nzn) should be divided by N to give us zn, before entering into column C. What you think?
  • #40
Good question. I intend to run a short example for which I know the answers already (N=4 only) to see what excel really does. It's too bad they don't reveal their algorithm, since there are innumerable versions of DFT's floating around.
  • #41
How did you get on RM? I've looked at various websites to establish how things work with excel, but they all have different answers, so am curious how your assessment went.
  • #42
Hang on, I think I finally have the goods, will send an updated worksheet today and also will try to go thru the theory. I've had to do a bit of re-education here myself!
  • #43
Brilliant, look forward to it
  • #44
Ok, here is (I hope) my final effort.
I strongly urge referring to the attached dft1.pdf file. I have used their nomenclature for most of my column headings.
First thing is that I had to consider the 1024 data points as current, not current-squared, since some of the numbers are negative.
My way of looking at it, what the OP's original graph showed was the rms current component divided by √2 (column J), which I think is weird since that divides each component amplitude by 2 instead of √2. Still, I decided to chart the J column to recall the OP's chart. You can change the J data to I data or whatever of course for a new chart.
I hope that most of my worksheet is self-explanatory. I apologize for my lousy chart, I never could figure out how to run my x-axis the way I want, the way the OP did (nice 100Hz segments running 0 to 500 Hz).
If the power density spectrum is desired my belief is that it has to be my column I which would give way bigger y-axis values, peaking at 504 A2 at f = 52.73 Hz.
Again, if you don't get my worksheet, or a strange one, pls. let me know. I do seem to have some problems sometimes with .xlsx files since I am running office 2003. (I almost quit my job when I found out what microsoft did to excel after 2003!).
BTW I ran the 4-data example in dft1.pdf using excel's data analysis package Fourier analysis and it agreed with the example's numbers for F[n] so that does give me confidence in using the excel program.
  • #45
BTW disregard the A and B columns far to the right. They were part of the OP's original worksheet. I did not compute these as I explained earlier.
I added column L which performs the inverse transform. Happily, all the f[k] values in columns B and L seem to agree.
  • #46
Hi RM, away for the bank holiday, but will take a look on my return. It's quite an interesting question.
  • #47
Sorry but I draw it in paint...:sorry:
  • #48
Going back to the calculation of the THD -
rude man said:
But your n=2 peak is at 8.77 A2 and the n=3 is at 6.25 A2 so why are you again taking rms of those two numbers? You didn't take the rms of 16, and rightly so!
Why wouldn't you take the RMS of 16? The question states that [itex]I_1[/itex] is the RMS value of the fundamental current. Is the [itex]16^2[/itex] a peak value or is it already an RMS value? I would have assumed it was peak. The same with [itex]I_2[/itex] and [itex]I_3[/itex].
I am getting :
[itex]\displaystyle\frac{1}{\sqrt{16}*\sqrt{2}} * \sqrt{\sqrt{2}*8.77+\sqrt{2}*6.25} * 100 = 81.43\%[/itex]
What have I missed here? Can anyone explain?
Thanks
  • #49
I am getting :
Thanks
Please see post #44. I again strongly advise scrutiny of the attached pdf file for the DFT theory.
Also, the attached excel file in that post gives the correct rms values (column G).
Keep in mind that the frequencies are the bin frequencies and the rms values the corresponding bin current values. If the data sampled three discrete frequencies the dft frequencies will be approximate of course.
To answer your question, you do take the rms of I1, I2 and I3 in the THD formula. (Actually, you could use the amplitudes too. Works either way).
I don't understand why you multiplied your I2 terms by √2 but the I2 values are incorrect anyway. I get THD = (1/22.46)*√(12.402 + 8.842) = 67.8%.
  • #50
Ok thanks RM, I'll give the pdf a thorough read and try again.
  • #51
Good. I would like to see the thread continue until everyone's happy!
  • #52
his_tonyness said:
Identify the principal frequencies in the current waveform
From the excel file, I have identified 3 principle frequencies at 52Hz, 246Hz and 351Hz. Is this correct? What does the term principle frequency actually mean?
Part 1 of this questions asks you to obtain the Fourier Transform for the data using the Fourier Analysis Tool of Excel. The transformed data should commence in cell D2.
I have done the analysis (attached spreadsheet), but am unsure exactly what data/figures i should put in my write up - can anyone advise?
  • #53
Or is it inferred that you've done it from subsequent answers?
  • #54
his_tonyness said:
Thats the darndest thing, the sample interval does not state the time units. "The supply current was sampled 1024 times over a very short time interval" that's all it gives me with regards to time, I assume we can use any sensible small time period. If you hover the mouse cursor over cell I3, it does state that the sampling frequency is 360/20ms=18000. I re-ran the simulation at 20ms:
Can i ask how you did this? Did you feed it the figures from the spreadsheet?
  • #55
I'm leaving this in the hands of earthloop and electest. :smile:
r m
  • #56
To answer my own question i can only assume it's inferred from subsequent answers that you've done it.
  • #57
The final part of this question is
Attempt to synthesise the shape of the original waveform from its principal harmonics [e.g. sketch the waveforms of the harmonics on the same time axis and add them together].
The principle waveform is at f = 52.7Hz and the harmonics are at 246.4Hz & 351.6Hz - what axis should i use for the waveforms?
  • #58
Can anyone offer the any assistance as to what axis to use when plotting the fundamental and the 2 harmonics?
I'm unsure how to get them to 'overlap' so i can subtract them.
  • #59
I'm so confused with this question different answers and calcs everywhere!
As the question asks for Rms, I found the square root of the I^2 values (which I assume are peak?), multiplied this by sqrt 2 to get RMS then plugged the values in??
1/5.635 Sqrt (4.1822^2 + 3.5364^2) then multiplied the whole thing by 100 to find the percentage.
Am I way off?
  • #60
Sorry to go all the way back to the beginning but...
The spreadsheet shows principal frequency as being the highest peak (I believe this is both I1 and n=1). This is 52hz with a magnitude of 15.878. I'm confused though as to Why 15.878 is just rounded up to 16 yet the 2 distortion frequencies are not rounded and stay at 8.77 and 6.25 respectively.
I've used data analysis on excel to produce the same graph but am in 2 minds what number to use for 1/(I1) when using the THD formula. Do I use 1/square root 15.878 etc etc or stick
with 1/square root 16 etc etc detailed above.
Thanks
  • · Replies 29 ·
  • · Replies 27 ·
11K
