Why Does My Probability Integration Yield 1/2 Instead of 1?
mathman44
I have that p(\theta)d\theta = \frac{1}{\pi}d\theta, this is definitely correct.
Also y=r*sin(theta) so dy=r*cos(theta)*d(theta).
Substituting d(theta) in above and simplifying, I have:
p(y)dy = \frac{1}{pi} \frac{dy}{\sqrt{r^2-y^2}}
The problem is, integrating this from y=0 to y=r, I obtain 1/2, and not 1, as expected. I don't understand why this is... anyone?
I'm not totally sure, but I think the problem is that in your integration your considering only half of the posibilities, I mean, you are only considering one half of the semi circle that can be described by the needle.
The min and max angles are \pi and 0. since y=r sin(\theta), you have y=0 for theta=0 or pi. This means that, when integrating between 0 and r, you need to multiply by a factor 2 to consider the whole spectrum.
Hope it helps...
Thanks, I thought exactly what you wrote. Still, is there any reason mathematically why this is so? When I do the same problem, but for the x-projection, this isn't an issue since the integration runs from -r to r.
Yes... the mathemathical reason is that the satisfied relation for trigonometric functions is \cos^2(\theta)=1-\sin^2(\theta), but when you replace \cos(\theta)=\sqrt{1-\sin^2(theta)} you are leaving out all negative values of cos(theta), i.e. all angles between pi/2 and pi... and so... you are considering only half of the posibilities.
Perfect. Thanks!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
