What is the kinetic energy distribution given the probability distribution?
jderm
Supose that a traffic study measures the speed at which people drive on the highway, and determines that the situation is well modeled by the probability distribution P(v)=Cv4e-v/vo. (a) If we are to measure speeds in mph, give the appropriate units for C and vo. (b) In order to perform an analysis of damages in crashes, transform that distribution into a distribution for kinetic energy.
the product p(v)*dv is a dimensionless quantity.
I understand that the units for dv are miles/hour, so p(v) is hour/miles.
therefore C must be in units (hour/miles)5
as for part B
K meaning kinetic energy
P(K)dK, dimensionless
i thinking that dK would be equal to .5*m*v*dv
and that P(K) would be P(v) multiplied by a constant 'A' (A having units hour/kg*mile)
so P(K)=ACv4e-v/vo units, (hour2/kg*mile2)
and dK=.5*m*v*dv units, (kg*mile2/hour2)
so if we were to intergrate,
fraction=p(k)*dk=p(k)*.5*m*v*dv=\frac{1}{2}ACm\intv5e-v/v0 dv
i think most people in the class just substituted 'v' with (2K/m)1/2, but i feel like that is incorrect, as you still need v to integrate.
is this the answer? is the constant 'A' necessary?
The probability distribution should really be
\frac{dP}{dv}=Cv^4e^{-v/v_0}
To convert to kinetic energy, use the chain rule
\frac{dP}{dK}=\frac{dP}{dv}\frac{dv}{dK}
You already have dP/dv but you need to calculate dv/dK.
Don't forget to change all occurrences of v into K, otherwise you will not have p(K). You do not need a separate constant A. When you are done, do dimensional analysis to make sure everything is in order.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
