Probability of No Consecutive Stations Between X and Y
  • Thread starter Thread starter gaganpreetsingh
    Probability
The problem involves calculating the probability that a train stops at three non-consecutive stations among n stations located between two cities, X and Y. Participants are exploring various approaches to determine this probability.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to derive the probability by considering total possibilities and exclusions based on consecutive stops. Another participant suggests using a matrix approach to visualize the stops. A third post reiterates the problem statement, while a fourth post offers a different method involving summation to count valid arrangements.
The discussion is ongoing, with participants offering different perspectives and methods. Some guidance has been provided, but there is no explicit consensus on the correct approach or resolution to the problem.
Participants are working under the constraints of the problem as stated, with no additional information provided about the nature of n or specific conditions beyond the requirement for non-consecutive stops.
gaganpreetsingh
There are n stations between two cities X and Y. At train is to stop at three of these n stations. Find the probability that no two of these three stations are consecutive.
This is what I did:
Total number of possibilities nc3 .
Now suppose that the stations train stops at is such that exactly two of these are consecutive.
(1,2) then it may stop at (4,5,6…..n) and no. of possibilities are n-3
(2,3) then it may stop at (5,6,7…..n) and no. of possibilities are n-4
(n-3,n-2) then it may stop only at n and no. of possibilities are 1
So the number of ways in which the train may stop at exactly two consecutive stations is
(n-3) + (n-4) + ……… + 1 n-3 terms
using formula of A.P. [n/2 (a+l)] n is no. of terms, a is first term, l last ]
possibilities are (n-3)(n-2)/2
Now if exactly 3 stations are consecutive then (1,2,3) (2,3,4)….. (n-2,n-2,n)
Hence here the no. of possibilities are n-2
So the things I have to exclude are (n-3)(n-2)/2 + (n-2)
Which is equal to (n-1)(n-2)/2
So we have Pr{event} = 1 – (n-1)(n-2)/2*nC3 = (n-3)/n
But I am not getting the right answer. Any help where my analysis is wrong?
Let's see... Suppose the train were to make 2 stops. You could make an n-by-n table, where a row shows the 1st stop and a column shows the 2nd stop. (E.g. if n=7 then the table will have 49 cells.) Since 1st stop < 2nd stop, you need to consider the cells above the diagonal only. The consecutive stops are of the form (k, k+1); they are the cells just above the diagonal. There are n-1 such cells.
Now you could apply this logic to your case (with 3 stops).
Gaganpreet Singh, nice to see another sardar here. :wink: WJKK WJKF! _/|\_
Do you have something to contribute to the discussion here?
The first stop can be anything betveen 1 and n-4. Let it be "j".
The second stop "k" can be any number from j+2 to n-2.
The third stop "l" can be any number from k+2 to n.
The number of possible arrangement of stops is
[tex]M = \sum_{1}^{n-4} \sum_{j+2}^{n-2} \sum_{k+2}^{n}1=\frac{(n-2)(n-3)(n-4)}{6}[/tex]
ehild
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 21 ·
