Probability that a two is thrown
  • Thread starter Thread starter Chewy0087
    Probability
The discussion focuses on calculating the probability of rolling a two with a biased die where numbers 5 and 6 appear three times more often than 2, 3, and 4. The initial calculation suggests that the probability of rolling a two is 1/9. For the second part, participants explore the combinations of two dice that result in a sum of 10 or more, leading to further calculations. Clarifications are sought regarding the nature of the die, specifically whether it is a standard six-sided die or a uniquely shaped one. The conversation highlights the importance of understanding the die's structure to accurately solve the probability questions.
Chewy0087
A die is based so that the numbers 5 & 6 appear 3 times more often than the numbers 2 , 3 & 4. Calculate;
i)The probability that a two is thrown.
ii)The probability that two consecutive throws are > or equal to 10.
Well I wasn't sure how to go about this so i imagined all of the outcomes;
5 5 5 6 6 6 2 3 4 , satisfies the criteria meaning a 2 would be 1/9, however i have a feeling that that's nonsense...:S
Then for ii) Combo's are 46 64 65 56 55 66 so (4 * 1/9) + (2 * (3/81) = (36/81+6/81) = (42/81)?
I don't know how to go about these questions, sorry for bugging everyone >.<
Well, here's another way of looking at (i) . . .
Let x be the probability that you roll a 2, then the probability that you roll a 3 or a 4 is also x and the probability that you roll a 5 or 6 is then 3x. We know that the sum of the probabilities of each possible outcome must be 1 so x + x + x + 3x + 3x = 9x = 1. Therefore x = 1/9.
Please clarify:
Did you mean to say "a die is biased so that..."?
Does the die really have five sides (such dice do exist) or is it that this is a normal six-sided die with repeated markings?
What is the probability of rolling a 1 if this is in fact a classically marked six-sided die?
Without this information, the question may not be answerable.
--Elucidus
sorry, yeah, having a 1 is impossible, i think it just means it's a wierdly shaped dice or something :S
edit: and thanks jgens that's a much simpler and better way of looking at it >.<
jgens has explained the first part. In order to answer the second part, you need to determine how the two dice might have a sum >= 10 and find the probability that those results could occur.
--Elucidus
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
