Problem in orienting two plates as instructed in question
- Thread starter gracy
- Start date
- Tags
- Plates
41 replies · 4K views
gracy
- 2,486
- 83
But from where is cylinder coming up?We were talking about plane/plate,right?
gracy
- 2,486
- 83
I know electric field due to uniformly charged infinite plane sheet is E=σ/(2ε0).Is this formula applicable always whether the sheet is conducting or non conducting?
- 13,438
- 8,113
If a uniformly charged sheet is infinite then, by symmetry, the component of the electric field parallel to the plate is zero everywhere. It does not matter whether the plate is conductive or not -- uniformly distributed charge will not flow to become non-uniform.gracy said:I know electric field due to uniformly charged infinite plane sheet is E=σ/(2ε0).Is this formula applicable always whether the sheet is conducting or non conducting?
gracy
- 2,486
- 83
So I can use the formula E=σ/(2ε0) in conducting as well as non conducting sheet,right?jbriggs444 said:It does not matter whether the plate is conductive or not -- uniformly distributed charge will not flow to become non-uniform.
gracy
- 2,486
- 83
please say "yes"gracy said:So I can use the formula E=σ/(2ε0) in conducting as well as non conducting sheet,right?
gracy
- 2,486
- 83
The why when dielectric is placed between the plates of capacitor there is decrease in electric field between the plates?ehild said:The superposition principle says that you can calculate the resultant field of several objects separately, as if the other objects were not there, and then sum the individual fields.
gracy
- 2,486
- 83
I meant electric field between the plates is less when dielectric is placed between them than when it is not.ehild said:Decrease with respect to what?
- 15,536
- 1,917
Supposing the capacitor is connected to a battery. You insert dielectric between the plates.What happens to the electric field?gracy said:I meant electric field between the plates is less when dielectric is placed between them than when it is not.
- 1,173
It happens because of the dielectric polarization. If instead of a dielectric, there were a conducting material, all the field would vanish.gracy said:I meant electric field between the plates is less when dielectric is placed between them than when it is not.
- Decimal
- · Replies 1 ·
- Introductory Physics Homework Help
- Replies
- 1
- sliperyfrog
- · Replies 2 ·
- Replies
- 2
- MaryCate22
- · Replies 5 ·
- Replies
- 5
- nadeem0322
- · Replies 1 ·
- Replies
- 1
- Karol
- · Replies 10 ·
- Replies
- 10
- Fluxthroughme
- · Replies 2 ·
- Replies
- 2
- Robin Lee
- · Replies 2 ·
- Replies
- 2
- maverick280857
- · Replies 4 ·
- Advanced Physics Homework Help
- Replies
- 4
