Problem that (probably) involves Archimedes' principle
When oil is added to the beaker, the tension in the string tied to the block is expected to increase. This is due to the change in buoyancy as the oil, which has a lower density than water, exerts additional upward force on the submerged portion of the block. The block's displacement of oil also contributes to the overall buoyant force acting on it. As a result, the tension in the string must adjust to balance the increased buoyant force. Understanding the relationship between buoyancy and tension is crucial in solving this problem.
tsw99
Serway book 14.26
The weight of a rectangular block is 15N. With a thin string, the center of the horizontal bottom face of the block is tied to the bottom of a beaker partly filled with water. 25% of the block is submerged when the tension is 10N
Oil of density 800 kg/m^3 is steadily added to the beaker and form a layer above the water and surronding the block. The oil exerts forces on each of the four side walls that the oil touches.
Explain what happens to the tension when oil is added?
I suggest the tension will increase by looking at the next question, but I really do not understand why the tension changes by adding oil. Not only the buoyancy changes because it also displaces some oil?
hi tsw99! :wink:
tsw99 said:
… I suggest the tension will increase by looking at the next question, but I really do not understand why the tension changes by adding oil. Not only the buoyancy changes because it also displaces some oil?
i assume that the string stays the same length, and the water stays the same volume, so the same amount of the block is "under" water, but some more of the block is now covered by oil
find the buoyancy force before, and the buoyancy force after :smile:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
