B Problem with an Equation -- Solving for "a" in this large equation
  • B
  • Thread starter Thread starter TheShermanTanker
TheShermanTanker
Ok, I know this may sound silly and I apologize for bringing in what should be a relatively easy equation. I'm trying to make the small a in the below equation the subject of the formula (That is, to push everything in the equation except a to one side of the equation and leave all the small letter a on the other side), but I'm getting stuck trying to do so halfway:
(Note: I'm trying to make the small letter a the subject of the formula, NOT the capital letter A's!)
246192
PS: The small dots you see in the equation are multiplication operators. They just mean this multiplied by this
Would appreciate any help for this! :)
Likes Buzz Bloom
Mathematics news on Phys.org
You could replace the many factors with a composite factor to reduce the equation to something a little more manageable:
##y = A ( (1/2)* ln ( B * sin^2(a) + 1) - ln ( cosh ( C / cos(a) ) * D - arctan ( v * sin(a) * E ) ) ) )##
where:
Code:
A = ...
B = ...
C = ...
D =  ( e^(...) - 1 )
E = ...
Likes TheShermanTanker
Hi TheShemanTanker:
I think that Jedishrfu's suggestion is a good first step, although I would also eliminate v, including it in E. I suggest the following as a second step.
Take the exponential of both sides.
ey = . . .
Hope this helps.
Regards,
Buzz
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
