Problem with charging a 12V1.3AH/20HR battery
  • Thread starter Thread starter Marquis
    Battery Charging
The user is experiencing issues charging a 12V1.3AH battery with two 100mAh solar panels, as the panels' indicator lights remain on, indicating no power is being delivered. They are considering using a 12V 4A car battery charger but are concerned about compatibility, as the charger specifies it should not be used with batteries under 20A. The battery was purchased recently, and the user questions whether it has been flat for an extended period. They also inquire about the meaning of "/20HR" in the battery's specifications. The discussion highlights the need for proper charging equipment and the potential for using a universal regulator to charge the battery.
Marquis
I've got a 12V1.3AH/20HR battery and I tried charging it with my 12V solar pannels of 200mAh max output together (2 solar panels with 100mAh max designed for charging car battery trough cigarette lighter thing) but the solar panels their lights wouldn't go off meaning no power were given to the battery (these blue leds light up when the panels do not power anything, they go off when I connect a solar panel to a little red led which then lights up for example)
Since the solar panels couldn't do the job for some reason I wanted to try with a car battery charger 12V 4A but it says don't charge batteries beneath 20A (and up to 70A max) =.=
Any idea why the solar panels couldn't start charging and why I can't charge it with the car battery charger(is this damaging for the battery or would it just not work or something)?
Already thanks for reading, hope you can help =)
Has the battery been sitting around flat (discharged) for a long time?
I wouldn't think so
Initial current : less than 0.39A
Cycle use: 14.4-15.0V
Standby use: 13.5-13.8V
Sealed Rechargable Baterry BAT-LEAD-02 (12V1.3AH/20HR)
(btw what's or why "/20HR"?)
[extra info]
bought it yesterday in a shop called Alfa Parts which is kinda just a shop where you can order stuff from a supplier, the initial order was from the shop itself which was 10 batteries of that type, they we're destined for something with pc's I think but ain't sure, they came in the shop on friday but I do not know the exact amount of time between shop, supplier and factory.
Found a "universal regulator", was actually looking for an adapter for a drill I had somewhere, turns out it's an
PRI: 230V~50hz 10.2W
SEC: 1.5-3-4.5-6-7.5-9-12
300mA 3.6VA
So I can regulate it from 1.5 to 12 V
Could it be used to charge that battery?
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
