What is the issue with this electrostatics problem?
  • Thread starter Thread starter NicolaiTheDane
    Electrostatics
NicolaiTheDane
I'm suppose to set a general function of the electric field, at any point in the xy plane. As the picture shows, there are 2 point charges with 1 charge, and 1 point charge with -3 charge. Each of them are equally distanced from the origin, and all 3 are evenly spaced apart.
I'm used Coulumbs law
First I defined all the point charge locations, along with an arbitrary point, to represent the unknown point of the function.
Then I merely use Coumlumbs law, to add up all the expressions:
The final expression isn't pretty at all though:
The field as displayed by maple (if one fixes the fieldstrength, otherwise some arrows become very very small) looks like this:
Which to me looks about right. However the vector function isn't divergence free, which suggests I have messed up something. What am I doing wrong?
The two dimensional function will not be divergence free, but if you included the z-component of the electric field, it would then be divergence free except at the locations of the electrical charges. ## \\ ## I didn't carefully check your equations, but they seem to be correct.
Likes NicolaiTheDane
Ahh alright then. Thanks a bunch! :)
What is also the case is that when you draw lines of flux for a 3-D case in two dimensions, the result is inherent inaccuracies where the density of lines doesn't fall off as inverse square, etc. The line density will be ## \frac{1}{r} ## in a 2-D diagram of a 3 dimensional case if they are drawn as continuous lines.
And an addition to post 2: You can see this with a single point charge: If you let ## E=\frac{Q}{4 \pi \epsilon_o}(\frac{x}{(x^2+y^2)^{3/2}} \hat{i} +\frac{y}{(x^2+y^2)^{3/2}} \hat{j}) ##, the divergence is non-zero everywhere, but if you write it as ## E=\frac{Q}{4 \pi \epsilon_o}(\frac{x}{(x^2+y^2+z^2)^{3/2}} \hat{i}+\frac{y}{(x^2+y^2+z^2)^{3/2}} \hat{j}+\frac{z}{(x^2+y^2+z^2)^{3/2}} \hat{k} ) ## and compute ## \nabla \cdot E ##, you will find it is indeed zero everywhere except at ## (0,0,0) ##.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
