Problem with Friction dependent on velocity, mostly a math problem.
  • Thread starter Thread starter Simen
    Friction Velocity
3 replies · 2K views
Simen
Hello, first time here for me, I hope I posted in the right subforum.
I have a task at hand, just started a new physics course, but sadly I am far from deft with mathematics, and my physics book is in a different language and uses different notation than I am used to. The part I am having trouble with is the following:
We have a block, with the starting velocity 5m/s.
The friction from the block is given as a = -μ|v|g
Where μ = 0.1 and g = 9.8 m/s^2
Find v(t)
v(t) = v(0)+at
a = dv/dt = (d/dt)(dx/dt) =(d2x)/dt2
As it stands now, I I realize I should integrate a in order to obtain v(t), but I am horrible at math, and do not know where to start, for some reason I keep ending up with an expression without v at all, but that does not help things either. If someone could show me the first steps in this that would be great. I've written a python program to solve it numerically as well, though I can not check if it is working, because I am too inept to get my analytical solution.
Would something like this be a step in the right direction?
a = -0.98|v|
v(0) = 5 m/s
a(0) = 0
dv/dt = -0.98*v
dv/dt2 = -0.98*v*dt
(dv/dt2)1/v = -0.98dt
And then integrate from here? Could someone show me an example? Doesn't need to have any of my numbers, so long as I can learn some of what I need from it.
If anyone could provide any help, that would be greatly appreciated!
Welcome to PF!
Hello Simen! Welcome to PF! :wink:
Simen said:
dv/dt = -0.98*v
(you left out a µ)
Now you "separate the variables" …
dv/v = -0.98µdt …
carry on from there :smile:
Thanks for the welcome:)
I actually didn't forget the μ, since μ = 0.1 and it was to be multiplied with g = 9.8 I just multiplied them before I started integrating.
Anyways, does this look right?
dv/dt = -0.98v
dv/v = -0.98dt
Integrate:
ln(v)-ln(v0)=-0.98(t-t0)
Clean up a little:
v/v0=e-0.98(t-t0)
v = v0e-0.98(t-t0)
Then putting in t0 = 0 and v0 = 5 and getting
v(t) = 5e-0.98t
Does that look about right?
Simen said:
v = v0e-0.98(t-t0)
v(t) = 5e-0.98t
(nice formatting, btw! :biggrin:)
Excellent! :smile:
(btw, always best to check by mentally putting the solution back into the original differential equation. to see if it comes out right … which it does! :wink:)
