Problem with my TI Calculator
  • Thread starter Thread starter njkid
    Calculator
The issue with the TI calculator not displaying the x and y axes can be resolved by enabling the "CoordinatesOn" feature. This setting is typically found under the "MODE" menu or possibly under the "SECOND GRAPH" or "SECOND Table" options. Users experiencing similar problems should first check the mode settings to ensure axes are activated. The solution was confirmed to be adjusting the settings to "2nd Format." Proper configuration of these settings is essential for accurate graph representation.
njkid
Mathematics news on Phys.org
njkid said:
Ok, somehow, my graph does not show the x,y axis.
I think there is no problem with my WINDOW...
How can i fix this?
WINDOW:
Xmin=-10
Xmax=10
Xscl=1
Ymin=-10
Ymax=10
Yscl=1
Xres=1
https://www.physicsforums.com/attachment.php?attachmentid=5550&d=1131859881"
Go to Second Graph or Second something...one of the Second Whatever commands and select the CoordonatesON
It might be under MODE. If not, it's under either SECOND GRAPH or SECOND Table I'm not sure. One of those anyway...Check in MODE first.
Thanks so much! It was 2nd Format.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
