Problems with Raman Spectroscopy
The discussion centers on issues encountered during Raman spectroscopy analysis of Propranolol HCl, where a specific batch fails to produce a detectable spectrum. Other analytical techniques, including infrared and NMR, yielded satisfactory results, indicating the problem is isolated to the Raman method. The spectrometer operates at a standard wavelength of 785 nm, and potential factors affecting the Raman signal include the material's fluorescence properties and physical characteristics. Suggestions include testing the spectrometer with known standards and adjusting experimental parameters such as exposure time and optical power.
  • Understanding of Raman spectroscopy principles
  • Familiarity with spectrometer operation and calibration
  • Knowledge of fluorescence effects on Raman signals
  • Experience with material characterization techniques
  • Investigate the impact of fluorescence on Raman spectroscopy results
  • Learn about optimizing Raman spectroscopy parameters, including exposure time and optical power
  • Research methods for characterizing material properties that affect Raman signal intensity
  • Explore troubleshooting techniques for spectrometer performance issues
Chemists, analytical scientists, and laboratory technicians involved in material characterization and spectroscopy who seek to resolve issues with Raman spectroscopy and improve analytical accuracy.
GuiHn
Hello,
Recently I had a problem in the analysis of a raw material called Propranolol HCl, when performing Raman identification for the specific batch the obtained spectrum does not generate signal and, consequently, identity of the material.
By testing other techniques like infrared and NMR, I got the results without problems.
It turns out that I need to understand why the problem occurs only in Raman spectroscopy. Searching the internet did not find anything that could explain, since the problem happens only with this lot in question, other lots of the same product provide perfect spectra.
Anyone who has good knowledge of the technique could help me?
Thank you.
Chemistry news on Phys.org
I'm far from an expert in the field, but my first intuition is to test the Raman spectrometer. Have you tried producing other spectra, such as for ethanol or acetone, which you probably have in your lab?
Hello, thanks for the help. In the laboratory we have a polystyrene standard that is made before any reading to evaluate the equipment. In addition, in the same equipment we made other batchs of the same product that had the spectra with normal intensity, only for this batch that we did not obtain spectra with product identity.
Initially I imagined that it could be a physical characteristic of the batch, but the granulometry and other aspects are similar with the other batchs that approved in the identification
That's strange. What wavelength is the laser?
Hello, the wavelength is the standart of equipament 785nm, I can't change this value.
I've been thinking that this raw material has a smaller fluorescence signal, but I don't have the equipment to prove it.
Some material have low raman intensivity. Do you have big thickness this material ? Do you have long exposition? Can you growing optical power up or wide slit?
  • · Replies 19 ·
9K
