Product rule for vector derivative
The discussion revolves around the application of the product rule for derivatives in the context of a position vector defined by a base frame and functions. The user questions how the frame e(t) can be treated like a function to apply the product rule, and whether the product rule extends to base vectors that are not strictly functions. There is a concern about the nature of the base frame, specifically if it is dynamic or constant, and how this affects the expression of the position vector. Additionally, there is confusion regarding why the product of the base frame and the position vector is not considered a function. The conversation seeks clarity on these mathematical principles and their implications in vector calculus.
Bullwinckle
Say I have a position vector
p = e(t) p(t)
Where, in 2D, e(t) = (e1(t), e2(t)) and p(t) = (p1(t), p2(t))T
And if I conveniently point the FIRST base vector of the frame at the particle, I can use: p(t) = (r1(t), 0)T
I want the velocity, so I take
v = d(e(t))/dt p(t) + e(t) d(p(t))/dt
And from there... blah blah.. I can take the rate of change of the frame, etc... but that is not my concern.
My concern is that I KNOW the product rule for functions: I can prove it and use the rule and it is for functions.
But here, I am using it here NOT for a product of two functions but for a product of a base frame and functions.
So, I can ask my question two ways and I hope someone can answer it both ways.
First, what is it about the frame e(t) that can enable me to treat it like function and blithely apply the product rule.
OR
Second, what is it about the product rule for functions that can enable me to apply it to base vectors so expeditiously?
In other words: does the base frame have the nature of a function, OR how does product rule for functions extend to the product of things that are not functions?
I'm not sure that I see your concern. e is a unit vector? Is it dynamic or constant? If it's dynamic, I would refrain from expressing it as (r1(t),0), as the second compenent will not always be zero. Also, why is the product e*p not a function?
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
Hello! I am generating electrons from a 3D gaussian source. The electrons all have the same energy, but the direction is isotropic. The electron source is in between 2 plates that act as a capacitor, and one of them acts as a time of flight (tof) detector. I know the voltage on the plates very well, and I want to extract the center of the gaussian distribution (in one direction only), by measuring the tof of many electrons. So the uncertainty on the position is given by the tof uncertainty...
