Projectile Motion - Acceleration and Angles
To calculate the total distance a jaguar jumps at a 30° angle with a speed of 3.33 m/s, the jump is divided into vertical and horizontal components. The vertical component is calculated as 1.67 m/s and the horizontal component as 2.88 m/s. To find the time taken to reach maximum height, the formula t = 2vsin(θ)/g is used, which gives the total time for the entire jump. For the time to reach maximum height, this total time is divided by two due to the symmetry of the projectile's path. The vertical motion can also be derived using the equation v_y = v_{oy} - gt, where at the peak, v_y equals zero.
jnrn
Finding the total distance a jaguar has jumped from a 30° angle at 3.33m/s.
I've split the jump into horiz./vert. components:
Vertical: v sin(θ) = 3.33sin(30) = 1.67 ms-1
Horizontal: v cos(θ) = 3.33cos(30) = 2.88 ms-1
I am just unsure as to how to find the time taken to reach maximum height using the vertical value in order to sub into the horizontal etc.
Any help is greatly appreciated!
the time is 2vsinθ/g,multiply by horizontal velocity to find distance.
Just to be a little clearer, the equation t = \frac{2vsinθ}{g}, tells you how long it takes for the projectile to cover the whole range.
However, in answer to your question about finding the time to maximum height, you just divide this expression by 2 since a parabola has symmetry about the apex.
Or it can be derived: v_y = v_{oy} - gt
At the top of flight, v_y = 0 => t = \frac{v_oy}{g} = \frac{v_o sinθ}{g}
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
