Projectile motion of a cannon ball
A cannonball is fired at a 40-degree angle, traveling 300 meters horizontally before hitting a cliff that is 10 meters higher than the cannon's position. The discussion involves calculating the initial velocity of the cannonball using projectile motion equations. The initial calculations suggest an initial velocity of approximately 42.71 m/s, but further verification indicates that the correct initial speed is 48.8 m/s. The calculations take into account both the horizontal and vertical components of motion, integrating to find time and position. The final consensus confirms the need for accurate calculations in projectile motion scenarios.
Ry122
a ball is fired from a cannon at an angle of 40 degrees to the horizontal and it travels 300m before hitting the side of a cliff which is 10 meters higher than the cannons position.
Determine the initial velocity.
The ball has a negative velocity when it hits the cliff.
My attempt:
Where v = the balls initial velocity
y component of velocity = -9.81t + Vsin40
integrate this and get
y position = .5*-9.8t^2 + vsin40t
x component of velocity = vcos40
x position = vcos40tUsing the expression for x velocity, solve for t at 300m in the x direction and get the expression
t=300/vcos40
Sub this into the expression for the y position above and solve for v.I'm unsure if this is the correct way to go about doing this. The velocity I ended up with is 42.7124ms^-1 which seems a bit slow for the distance it covers.
Your method is correct.
I check your answer, but I got the initial speed is 48.8 m/s.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
