Projectile motion on an incline
To solve the projectile motion problem on an incline, establish a coordinate system aligned with the incline and derive the equations of motion accordingly. The distance traveled along the incline can be calculated using these equations. The angle that maximizes the distance is influenced by the incline's angle and requires careful consideration of the launch parameters. A scaling trick related to variable selection may simplify the calculations. Understanding these principles will lead to a solution for both the distance and optimal launch angle.
sigma
Hi. Got this quite interesting problem:
A projectile is launched at some velocity at an angle a over a plane inclined at an angle b.
1. How far, measured along the incline, will the projectile fly?
2. What angle a will give the longest distance?
Any suggestions/hints on possible solutions?
/J.
Set up coordinates in the plane of the incline and write out the equations of motion. You should be able to solve them with little difficulty and arrive at the desired answer.
There is a trick with scaling and your choice of variables, but I can't remember it, if you look at the flat example the choice of variables might be obvious
