Projectile motion question with angles and velocity
The problem involves calculating the initial speed of a baseball hit by Joe Carter, which cleared a 10m fence and landed 8m beyond it, with the ball's trajectory at a 45-degree angle. The discussion emphasizes that air resistance is negligible, allowing the initial and final velocities to be equal. To solve the problem, participants suggest breaking it into two parts: the motion before and after the fence. They note the need to establish equations for horizontal and vertical motion as functions of time, using the coordinates where the ball clears the fence as the origin. Ultimately, the solution requires setting up equations based on the ball's position at the time of impact to determine the initial speed.
thedropsoffir
Joe Carter hit a fly ball during the spring training. It just cleared a 10m high vertical fence on the way down at 45 degrees as shown and struck the level ground 8m beyond the fence. Calculate the speed of the ball when it left his bat at ground level (start and end points are the same, ignore air resistance). Answer in m/s.
∆x = vit
5 kinimatics equations for y direction
Since air resistance is negligible, and the ball starts and ends at the same level, vi = vf
a = 9.8 m/s down
We can break equation into 2 parts - part 1 before fence and part 2 after
For Part 2
∆dix = 8m
∆diy = 10m
a = 9.8 m/s (down)
vf = vi of part 1
vf = ?
It seems we're missing time and vf, two variables of the equation for part 2, and several variables for part 1. If you guys can help me figure this out that'd be sweet.
Wherez the figure?
Use coordinates with the spot where the ball cleared the fence as origin. The time coordinate will also be 0 when this happens. Call the speed of the ball at this point v.
This is the initial speed.
Since we know the angle we have v_x = cos(45)v and v_y = -sin(45)v.
note that cos(45) = sin(45)
Now write down expression for x and y as a function of t.
x(t) = ...
y(t) = ...
The ball will hit the ground at x=8, y=-10. call the time this happens T.
if you then set x(T) = 8 and y(T) =-10 you get 2 equations for v and T.
The v you find from that is at the top of the fence, so you'll need to compute v_x(T) and v_y(T) to get the speed at the point the ball hits the ground.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
