Does air resistance affect projectile motion?
Air resistance significantly affects projectile motion, particularly when calculating the time for a projectile, such as a ball, to return to its original position. Standard equations of motion, which assume constant acceleration, neglect air resistance, leading to inaccuracies in scenarios involving high speeds or significant heights. The error introduced by ignoring drag is minimal for low-speed throws but becomes substantial for high-altitude drops. The equations of motion become exponential when accounting for air resistance, as the drag force is proportional to the instantaneous velocity of the object.
  • Understanding of basic physics concepts, particularly Newton's laws of motion.
  • Familiarity with projectile motion equations and their derivations.
  • Knowledge of air resistance and drag force principles.
  • Ability to analyze motion under varying forces, including constant and variable acceleration.
  • Study the effects of air resistance on projectile motion using computational simulations.
  • Learn about the mathematical modeling of drag forces in physics.
  • Explore advanced topics in fluid dynamics related to projectile motion.
  • Investigate real-world applications of projectile motion equations in sports and engineering.
Students of physics, educators teaching mechanics, engineers involved in design and analysis of projectile systems, and anyone interested in the effects of air resistance on motion.
Physicist
Hi all,
If someone threw a ball vertically & we want to calculate the time needed to for the ball to return back to his hand taking into account air resistance, would it be different if we ignore air resistance??
When they derive the known laws for the maximum height, range & time, did they ignore air resistance?
Thanks
Yes. They do ignore wind resistance. The standard equations of motion that most people are familiar with deal with a constant acceleration. Wind resistance is not constant.
The amount of error induced is going to depend greatly on the gemoetry, displacemets and speeds involved. In your example of tossing a ball, the error induced by not taking into account drag would be much much less (probably an order of magnitude less) than if the ball was shot up thousands of feet and allowed to come back down. The speeds the ball would reach being thrown would not come close to the speeds it would reach if it fell from a thousand feet. Also consider the fact that if a ball were dropped from a sufficient height, the ball would eventually stop accelerating (due to drag) and would fall at a constant speed.
Also, consider what the equations would tell you if you calculated how long it would take a flat piece of paper to fall from some height. It wouldn't be even close because in that case wind resistance plays a huge role.
It is up to the person applying the equations to make the proper assumption as to whether or not neglecting a complex term is a proper assumption to make.
Maximum height, range and time of what?
generally the air resistance is proportional to the instantaneous velocity of the body...so when u actually calculate the equation of motion it is exponential
  • · Replies 19 ·
12K
