Projectiles - person kicks a soccer ball at an angle
Kicking a soccer ball at an angle involves understanding the initial vertical and horizontal components of its velocity. The maximum initial vertical component occurs at a 90-degree angle, while the maximum initial horizontal component occurs at a 0-degree angle. However, a 45-degree angle maximizes the range of the projectile. The discussion clarifies that the question specifically asks for the greatest components separately, not simultaneously. Therefore, the optimal angles for each component are distinct, with vertical at 90 degrees and horizontal at 0 degrees.
Coco12
Projectiles -- person kicks a soccer ball at an angle
a) A person kicks a soccer ball at an angle and sends it in the air. What angle of projection between 0 and 90 degrees produces the greatest initial vertical component? Greatest intital horizontal component?
Using cosine, sine of triangle.
Would it be 90 degrees for the intital vertical component and 0 degrees for the horizontal component? Is that possible?
If the intial angle is 90 or 0 then it would be linear motion in vertical or horizontal direction respectively, so if you need maximum vertical and horizontal component for given intial velocity in a projectile then it must be 45 degree.
So the angle for both initial horizontal and vertical component is 45 degrees?
Not sure that means anything. If you maximise the one you will not maximise the other. It certainly isn't what the question asks for. Coco12's answer looks right to me.
Let u, ux, uy be the intial velocity, x component of velocity, y component of velocity respectively.
We know ux=u*cosθ , uy=u*sinθ where o<=θ<=90.
So θ=45 is the only angle for which both components are maximum. You can verify it by plotting sine and co sine curve graphically and see it.
ajayguhan said:
Let u, ux, uy be the intial velocity, x component of velocity, y component of velocity.
We know ux=u cosθ , us=u*sinθ where o<=θ<=90.
Neither is maximised at 45 degrees. 45 degrees maximises max{ux, uy}, but that is not the question.
He wants to find the maximum vertical and horizontal component of the displacement vector?
I know that 45 degrees gives you a max range value however the question is asking for the greatest intital vertical component and the greatest intital horizontal component, so wouldn't that be different or?
Intial vertical and horizontal component of what? Wether it is displacement, velocity, acceleration.check the question carefully!
Initial displacements are necessarily zero. It can only be referring to velocity components.
It doesn't indicate whether it is velocity or displacement, etc. it just says intital horizontal and vertical components
So what would the initial vertical displacement be? Is asking for its maximum a sensible question?
Either acceleration and displacement would make no sense. So it must be velocity in that case the answer is 45 degree.
Yes, it must be velocity. But the answer is not 45 degree. For a given magnitude of velocity, at what angle is the vertical projection the largest?
90 degree. Whether the question is find the angle which maximizes both or just separately vertical and horizontal component. If it was the latter case then the for vertical and horizontal component the angles are 90 and 0 respectively.
The question is clear. It asks two questions. One about vertical component. The second about horizontal component. They are even in two different sentences.
And 45 degrees does not maximize any of the two component. Either one can be increased more by changing the angle from 45 degrees.
45 degrees maximizes the range but this is another story.
