Choosing the Right n Numbers from {1,2,3,...,2n}
  • Thread starter cragar
  • Tags
    Numbers
In summary, the conversation discusses proving that if more than n numbers are chosen from the set {1,2,3,...,2n}, then one number must be a multiple of another. The attempt at a solution suggests picking the top half of the set from n+1 to 2n to avoid picking a multiple, but it is asked if this can be avoided with exactly n numbers. The conversation continues with discussing the proof that n+1 cannot be avoided.
cragar
2,552
Prove that if one chooses more than n numbers from the set {1,2,3, . . . ,2n}, then one number is a multiple of another. Can this be avoided with exactly n numbers?
If we pick the top half of the set n+1 up to 2n we will have n numbers that are not multiples of each other. the smallest multiple of n+1 is 2(n+1) but this is outside the set. and there are n numbers from n+1 to 2n. if i pick numbers below n+1 then their double would be in the top half of the set. so the best way to pick them is the top half of the set from n+1 to 2n
That certainly is a way to pick n without picking one that divides another. What about the proof that you cannot pick n+1?
1. What is the purpose of choosing n numbers from the set {1,2,3,...,2n}?
The purpose of choosing n numbers from the set {1,2,3,...,2n} is to create a subset of numbers that can be used in various mathematical and scientific calculations. This subset is often chosen based on specific criteria or requirements for a particular experiment or study.
2. How do you determine which n numbers to choose from the set {1,2,3,...,2n}?
The process of choosing the right n numbers from the set {1,2,3,...,2n} involves careful consideration of the specific requirements or criteria for the experiment or study. This may involve using mathematical formulas or algorithms to select the most appropriate numbers.
3. What factors should be considered when choosing n numbers from the set {1,2,3,...,2n}?
When choosing n numbers from the set {1,2,3,...,2n}, factors such as the desired sample size, the range of numbers needed, and any specific patterns or relationships between the numbers may be taken into account. The goal is to select a set of numbers that best fits the requirements of the experiment or study.
4. Can the same n numbers be chosen multiple times from the set {1,2,3,...,2n}?
It depends on the specific requirements for the experiment or study. In some cases, it may be necessary to choose the same n numbers multiple times from the set {1,2,3,...,2n}. However, in other cases, it may be preferable to choose a unique set of n numbers each time.
5. How does the size of n affect the process of choosing numbers from the set {1,2,3,...,2n}?
The size of n can greatly impact the process of choosing numbers from the set {1,2,3,...,2n}. As n increases, the range of numbers available to choose from also increases, which may affect the complexity of the selection process. Additionally, the size of n may also impact the statistical significance of the chosen numbers in relation to the overall set.
