Proof by Induction Question on Determinants and Eigenvalues
The discussion revolves around proving by induction that if \(\lambda\) is an eigenvalue of a square matrix \(A\), then \(\lambda^n\) is an eigenvalue of the matrix \(A^n\) for all positive integers \(n\). The participants are exploring the implications of this statement within the context of linear algebra, particularly focusing on eigenvalues and determinants.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish the proposition \(p(n)\) involving determinants and eigenvalues but struggles with factorization and the application of induction. Some participants suggest alternative methods, including using the definition of eigenvalues directly instead of determinants. Others propose hints related to factorization of polynomials.
The discussion is active, with participants providing hints and alternative approaches. There is recognition of the challenges faced in using determinants, and some participants express a shift in understanding towards a more straightforward method involving eigenvectors. However, there is no explicit consensus on a single approach yet.
Participants are navigating complexities related to the proof structure and the mathematical properties of eigenvalues and determinants. There are references to specific mathematical rules and identities that may not be universally known among all participants.
Abuda
Thanks, although I still haven't managed to factorise the expression although I did type it up in LaTeX!
Prove by induction that the following statement is true for all positive integers n.
If [itex]\lambda[/itex] is an Eigenvalue of the square matrix [itex]A[/itex], then [itex]\lambda^n[/itex] is an eigenvalue of the matrix [itex]A^n[/itex]
I think the relevant equations are:
[tex]\det(A-\lambda I)=0[/tex]
(where I is an identity matrix)
[tex]\det(AB)=\det(A)\det(B)[/tex]
So, in mathematical terms I converted the question into the proposition p(n). I got,
[tex]p(n):\det(A^n - \lambda^nI) = 0[/tex]
Now I assumed that p(n) is true for some value k, so I got,
[tex]p(k):\det(A^k - \lambda^kI) = 0[/tex]
I know that p(1) is true so all I need to do is prove that p(k)=>p(k+1)
So I need to show that [itex]\det(A^{k+1} - \lambda^{k+1}I) = 0[/itex] by using the assumption.
I tried a couple of things here that got me no where. I multiplied both sides of the assumption by det(A) and got:
[tex]\det(A^{k+1} - A\lambda^k I) = 0[/tex]
But I saw no continuation. I also tried [itex]A^n=PD^nP^{-1}[/itex] and got something incredibly messy but it didnt work for me.
Thanks for all help in advance.
Welcome to PF!
Hi Abuda! Welcome to PF! :smile:
(try using the X2 icon just above the Reply box :wink:)
Hint: factor An - Ln :wink:
(though I don't see what that has to do with proof by induction :confused:)
I edited the question to make it readable as you suggested tiny-tim! And thanks for the welcome. But I'm still confused due to my being not able to factorise it :S
You are probably better off doing this without the determinants. If x is an eigenvector of A with eigenvalue lambda, then Ax=(lambda)x. Try doing induction with that definition.
Thanks for the simple answer Dick! I think I got the answer. I got:
[tex]P(n): A^nx=\lambda^n x[/tex]
P(1) is true
Assume P(k) is true.
[tex]P(k): A^kx=\lambda^k x[/tex]
Multiplying both sides of p(k) by A yields:
[tex]A^{k+1}x=\lambda^{k}Ax[/tex]
Now we sub in [itex]Ax=\lambda x[/itex] from the definition of eigenvalues.
[tex]A^{k+1}x=\lambda^{k+1}x[/tex]
Therefore, p(k) implies p(k+1) and hence p(n) is true for all n. It seems that I spent a lot of time on the method using the determinant approach but I realize now that the determinant approach couldn't have worked easily as the substitution of Ax=lambda x couldn't have been carried out...Thanks heaps Physics Forums. Its a pleasure to have joined your website!
Alex
just for the record, my idea was An - Ln = (An-1 + An-2L + … + Ln-1)(A - L) :wink:
Oh Yeah! Because we know that Det(AB)=Det(A)Det(B) and Det(A-L)=0 we can prove it directly without induction using the determinant approach. Great idea. I tried to factorize it briefly before I posted the question but I didnt even know the rule you posted so I had no success!..Thanks again
Alex
Hi Alex! :smile:
Abuda said:
… I didnt even know the rule you posted …
oooh, in that case for future possible use you also need to learn …
An + Ln = (An-1 - An-2L + … - ALn-1 + Ln-1)(A - L)
(with alternating + and - signs, and it only works for odd n :wink:)
of course, these work for ordinary numbers also
tiny-tim said:
Hi Alex! :smile:
Thanks Tim, Excellent, I put them down in book! :)
  • · Replies 18 ·
  • · Replies 24 ·
