How Does Reduction of Order Help Solve Non-Homogeneous Differential Equations?
  • Thread starter Thread starter Panphobia
    Proof Reduction
Panphobia
The method of reduction can be used to solve non-homogeneous equations with non-constant coefficients given by y''+py'+qy=g
If Y1 is a known solution to the corresponding homogeneous differential equation, let
y = vY1, w = v'
Show that if w satisfies the linear first-order equation
Y1w' + (2Y1' + pY1)w = g
then y is a solution of the original differential equations
[/B]
I am not exactly sure what I am supposed to prove here, am I supposed to prove that w satisfies that equation and then take that y is a solution as a given, or am I supposed to take that w satisfies that equation, solve it then prove y is a solution?
Imagine for a moment you have an ordinary, second order, linear, homogeneous differential equation in Cauchy Euler form:
$$ax^2y'' + bxy' + cy = 0$$
This will be used to explain reduction order. In standard form, the equation takes the form:
$$y'' + \frac{b}{ax}y' + \frac{c}{ax^2}y = 0$$
$$y'' + p(x)y' + q(x)y = 0$$
The point ##x_0 = 0## turns out to be a regular singular point since ##p(x)## and ##q(x)## are not analytic at ##0##, but ##(x - x_0)p(x)## and ##(x - x_0)^2q(x)## are both analytic at ##0##. The solution may be undefined at ##0## as a result, so assume ##x \neq 0##. So for ##x > 0##, we seek solutions of the form ##y = x^r##.
Taking derivatives ##y'## and ##y''##, and plugging them back into the original differential equation, the indicial equation is obtained:
$$ar(r - 1) + br + c = 0$$
Suppose the indicial roots are equivalent, that is ##r_1 = r_2##. Then one solution of the Cauchy Euler equation takes the form:
$$y_1 = x^r$$
Where ##r_1 = r_2 = r##. In order to determine a second solution, employ reduction of order. So set:
$$y_2 = u(x)y_1$$
We must now determine ##u(x)## in order for ##y_2## to be a solution. The way you do this is by taking derivatives once more:
$$y_2 = u(x)y_1$$
$$y_2' = uy_1' + u'y_1$$
$$y_2'' = uy_1'' + 2u'y_1' + u''y_1$$
Subbing these derivatives back into the Cauchy Euler equation and doing some math will allow you to find ##y_2##.
The process of reduction order is the same for other equations. You start with one solution ##y_1## and determine a second solution ##y_2 = u(x)y_1## by finding a function ##u(x)## that makes ##y_2## a solution.
y = vY1, w = v'
[/B]
What you are to do is take the first and second derivatives of y= vY1, insert them into the given second order equation, and show that this can be reduced to the correct first order equation for w.
