Proving Taylor Series: Maclaurin vs. Taylor
Proving Taylor series involves demonstrating that a function can be expressed as a power series around a point, with the Maclaurin series being a specific case at zero. The process typically starts with Taylor's theorem, which establishes the relationship between a function's derivatives and its Taylor polynomial. A function must be continuously differentiable to apply this theorem effectively, and the error term in the approximation must approach zero as the degree of the polynomial increases. Some discussions suggest that proving the Maclaurin series inherently involves understanding the Taylor series, as it relies on similar principles. Complex analysis provides an elegant proof using Cauchy's Integral Formula, linking the coefficients of the series to the function's derivatives.
rock.freak667
How does one prove taylor series? Is it proven the same way as Maclaurin's Series(Which i know is a special case of taylor series)
f(x)=A_0+A_1x+A_2x^2+A_3x^3+...
f(\alpha)=A_0+A_1\alpha+A_2(\alpha)^2+A_3(\alpha)^3+...
this kinda doesn't seem like a good way to prove it...as that is how I know how to prove maclaurin series
Mathematics news on Phys.org
Can you state precisely what is "it" that you are trying to prove?
If I understand your problem, f(g(x))=f(x-a) is just as differentiable as f is. Although, the logical approach taught in analysis courses is to prove Taylor's theorem and then the result about Maclaurin series holds at a=0.
I'm not even sure if you prove the result for Maclaurin series without implicitly proving Taylor series.
Well I am trying to show that if a function is differentiable at x=a
then f(x)=f(a)+f'(a)(x-a)+f''(a)(x-a)^2/2!+...
I never learned Taylor series...but I was yet shown Maclaurin's series and how to prove it without know that maclaurin's series is just a special case of Taylor series
The Taylor series is not so easy as it looks. The general result is the following.
First, a class C^n function on (a,b) (with a<0<b) is continously differentiable n times. Then the polynomial T_n(x) = \sum_{j=0}^{n} \frac{f^{(j)}(0)}{j!}x^j has the property that the error, i.e. R_n(x) = f(x) - T_n(x) satisfies \lim_{x\to 0}\frac{R_n(x)}{x^n} = 0. This is a result which becomes of theoretic important.
Wikipedia's article on Taylor Series has several different proofs, I'm sure you can read them there. The simplest one by memory was the integration by parts one.
I didnt see any proofs when i checked it
EDIT:I see it ...thanks
Well Taylor series is a simple consequence of Cauchy's Integral formula. That is if you allow a complex analysis based proof(real ones aren't all that elegant).
For any analytic function f(z), represent with the integral formula for any suitable disc centred at say a and expand the denominator in a geometric series such that the intgration variable isn't caught up in it. Seperate the integral inside the sum and there's your Taylor coefficient. The fact that this is a higher derivative of the original function is again a simple consequence of the Cauchy Integral Formula(which isn't terribly difficult to prove using Cauchy's theorem once you understand the basic notions of holomorphism)
